I have a maytag neptune front load and it leaks from the bottom left during the rinse cycle. Whats wrong? How can I fix it?
Take the cover off the back, and look up, next to where you put the soap in, when it's filling/rinsing. There is (like) a (white) plastic valve body, and look to see if water is dripping out of it. I haven't figured out a solution to that yet, other than to replace it.
Also check the boot, coming off the pump. You could have a bad/dry boot, or a loose hose clamp.
