Display board want respond
SOURCE: The Incline is stuck at an angle
Check the motor and the gears that run the unit up and down. If is located on the front of the unit under the face plate. make sure everything is power everything. Also check the gears to make sure they did not break and check the tracks to make sure it did not fall off the track causing it to stay up
SOURCE: How do you put the treadmill down?
There is a knob on the support bar behind the treadbelt deck. Give the deck a little push up, then pull the knob out and lower it.
SOURCE: IPEC TREADMILL
What I have done, is remove the case to access the incline assembly. tyically a black tube looking thing with a small motor attached to its side. at the end of this motor, you may see the shaft to the motor, with a slot cut in it,.like a flat head screw driver. use a cordless drill with a standard bit attached to rotate the motor manually.
SOURCE: I have an Epic t60. The incline stopped working. I
Try to recalibrate the incline. Start the machine running, press the incline up button, then pull the safety key off. Release the incline up button and replace the safety key. The treadmill should go to maximum incline then minimum. after calibration is completed, retry the treadmill operation.
