I have a Polaroid HDTV with a DVD player in the side of it. There's a DVD stuck in there and I can't get it out. It just makes a clicking sound when I press open.
When I push eject, it makes a noise and then nothing comes out. The dvd will play, so I know it is in there! This is a Polaroid flat screen with built in DVD player on the side.When I push eject, it makes a noise and then nothing comes out. The dvd will play, so I know it is in there! This is a Polaroid flat screen with built in DVD player on the side.
You can't post conmments that contain an email address.
I have had this before, get yourself a butter knife, slide it gently into the space, and try to maneurver the dvd back a little, and while you have the butter knife in, push your open/close button, hope this works for you it did for me!
Tries the tv unplug/replug the tv back for about an hour later for the tv power to reset itself.At this time u will able to eject the DVD disc out.Don't tries to used the tv intergrated DVD player anymore.The tv intergrated DVD player laser head and the spin motor for the dvd disc spinner it is defective now.Buy a portable cheap or a moderate unit of a outer DVD player and hook up to the tv AV input.Play it through the tv input video 1,2,3 u should have a DVD player capatablities again.
Can't find a code to program your universal remote to control your Polaroid HDTV / DVD combo? Can't find a listing for Polaroid DVD in your remote control code list?
Many manufacturers recycle remote control codes, so often the best solution is to use the code search function of your universal remote.
Here are some remote control codes that have worked to control Polaroid HDTVs:
My 19" w/DVD uses the following Mitsubishi code: 10178
Dish Network remotes: 627, 659, or 688
DirecTV RC64 remote control revealed a code of 10835. This means that 10835, 0835, 835 or some variant many work with many programmable remote controls. On my DirecTV DVR system, this was indicated as a Moxell and/or Motorola TV code.
Use the mitsubshi tv codes they worked for me.
Try Element codes if they are listed in your remote code list.
If the DVD doesn't start when you place it in the player, look for the Play button on the remote control. There may be a TV/DVD switch on the remote that would need to be changed to DVD.
If the manual below doesn't match your TV, please post the model number of your Polaroid HDTV/DVD combo for more specific help.
