- I have never dropped it.
The device probably can with a Buffalo utility/driver disk. The other computer will need these drivers to recognize the device. If you lost the driver disk, you can download them here: http://www.buffalotech.com/support-and-downloads
SOURCE: buffalo ministation
if you dropped your hard-drive and it stopped functioning - high chances that the drive has a physical crash. Best suggestion will be to contact a professional data recovery team if the data on the drive is really important (Coz, they charge a bomb for the recovery) Suggestion would be to talk to drivesavers.com
SOURCE: How to open the case safely (without damaging it)?
Remove all screws from the enclosure, and then slide a then metal (non magnetic) slide to pop the clips off of the sides of the enclosure, lengthwise. You can do it without breaking the plastic
SOURCE: can't see my buffalo usb ministation under my computer
right click on my computer click manage, then in the new screen click on disk management, can you see the device there? if so right click on it and click delete partition, then after right click and make a partition and format it with a quick format, this should then show it in mycomputer ,this will delete all data on the hard drive!
SOURCE: cannot access data in my buffalo ministation orange light showing
Try accessing it in another USB port or computer. If still not, it may unfortunately be damaged. You may be able to get it replaced under warranty.
SOURCE: Computer not accessing Buffalo HD
my Buffalo external hard disc can be detected by laptop, but my access is denied. When i click on the hard disc icon, it popped out a message box prompting me to reformat my hard disc. Is there any other way to retrieve my files before reformat or
is there any other way to recover my files after reformat?
Is there any other way to troubleshoot my hard disc other than reformatting it?
Please help me, I am desperate to recover all my files because they are too important/precious to lose it.
Download the
HDD Unlock Wizard HDD Unlock Wizard v4.2 http://www.filebuzz.com/publisher/download.php?id=98078
HDD Unlock Wizard is a window based utility.
It works as a new life for your locked hard disks, as it is competent to unlock almost all hard disks of major brands available in market.
Its proprietary unlocking algorithms can remove any unknown HDD password and you do not required to give any hint of password as it is not working as a normal password cracker tool.
Removal of a HDD password is a slow process and total time required to remove HDD password is depending on the size of the hard disk and type of hard disk.
A small 2.5" notebook hard disk takes more time as compared to normal Desktop hard disk.
Presently it supports IDE and SATA hard disks.
hope this helps
also you might try
http://download.cnet.com/siw-portable/3000-2094_4-75449686.html
Software Inventory: Operating System, Installed Software and Hotfixes, Processes, Services, Users, Open Files, System Uptime, Installed Codecs, Software Licenses (Product Keys / Serial Numbers / CD Key), Passwords Recovery.
