The camera powers up and everything seems to be working, but I cannot see anything on the screen. When I connect the camera to my TV screen I can see the viewfinder, browse pictures etc. Any ideas? thanks, Simon
A screen fails in one of two ways. 1.Backlight goes- If looked at closely or to one side the images are there as ghosts but not illuminiated. 2. Connector or board component has failed which could mean with a back light Okay a brilliant white screen. Failure 1 - nothing for you to do there Failure two -if it is a connector- gently flexing the camera casing in the region of the base of the screen may elicit a reconnect. In either case however- I think you will find that unless it is under warranty or insured in some way- New camera will be a more economical approach. But check out makers support site first.
Same problem - camera only 3 weeks old. Screen failed after down-loading images to the PC. Everything else seems fine.
