CD/DVD Drive Tray problems There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work. Go to My Computer and right click on the drive and click on Eject. If this does not work then you can manually open the CD/DVD drive tray by - Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc. If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
There are two ways to open the CD drive door if the button just below the drive tray does not work. Go to My Computer and right click on the drive and click on Eject. If this does not work then you can manually open the CD drive tray by - Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc. If you continue having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Try this: Remove Mini from A/C power; remove battery. Hold power button for 10 seconds; reinstall battery & A/C power. Try starting normally. Your netbook doesn't appear to have an external VGA port, or I would suggest trying to connect to an external monitor. Your monitor back-light may be burned out.
with your computer power turned off, use a straight mini-kabob pin (or sturdy paper clip) to manually let out the DVD drive tray. There is a little hole under the drive tray door that accepts this kind of tool device. Another option is to massage the door while trying to eject the DVD drive tray. This method requires your computer to be turned on and by selecting the proper drive (E:) from the My Computer in Start Menu, you then "Eject" and can push in on the door and on the corners, enabling the DVD drive tray to open.
Look at the drive there should be a tiny pin hole near the eject
button, insert a needle (safety pin, sewing, etc.) into the pin hole
and push this opens the drive.
You can also try opening my computer and right clicking the DVD drive and select eject.
To the left of the Eject Button/Activity Light is a Disk Eject Hole. It will be a very small hole big enough for you to straighten out a paperclip and push in to hit the eject the disk
is the light flashing on the drive ? .... be that as it may you will note a small hole on the face of it.... put a small round object in there and push... that should open the door.
No bios no post and no power lights on disk drives means hardware problem.
Either call a technician or try the following if you feel you can do it yourself, beware , there is always risk of damaging your PC on DIY.
unplug the computer, open PC and remove all plugs and internal and external devices, leaving only a minimal set of devices.
Start the motherboard with only Power adapter , one RAM module, and video card and screen connected. Unplug all disks and external devices, remove all pci cards.
If it still does not start take it to a repair shop, you may need to replace power supply, motherboard or ram.
try, go to my computer>properties>hardware tab>device manager and go down the list to cd/dvd drives, click on the '+' and right click on your listed drive and select uninstall.
restart the notebook and then the drive will be re installed with drivers automatically.
it may be a firmware or driver error.
