Do I need to open up engine and pull bolt out..? Or can I just replace the bolt.. And leave the broken piece in there without it affecting anything??
To replace the bolt you'll need to remove the broken bolt that is still in the head. To do this you need to drill a hole in the center of the bolt. And then you'll need to use a bolt extractor to screw the broken bolt out. than you can install a new bolt.
Where can I get the extractor? Thank you
tHE EXTRCTOR IS ALSO CALLED A EASY OUT. yOU CAN BUY IT AT THE AUTO PARTS
Take the bolt with you and show it to the guy at the counter. He can sell you the drill bit and the easy out that will work for your bolt size.
Alright ill go up and get them both... Thanks a lot man I really appreciate it..
SOURCE: 1998 Saturn SL idler pulley broke off and bolt is stuck in engine
The idler pully can be removed without removing the engine. I have replaced mine in my 97 SL2. As to the bolt breaking off, that is strange. I assume that if the bolt broke off, then the idler pully also fell off. If I remember, the space is somewhat limited, so getting a removal tool in there could be very difficult, especially if the bolt is flush with the mounting hole. That doesn't sound like a fun project. If bolt protrudes, maybe you can get some vise-grips on it and turn it out.
SOURCE: need to replace broken lug bolt
If you have room behind the broken lug you can usually drive it out with a good smack of a sledge hammer. To re-install, use a stack of washers between the nut and flange and draw the lug into position. (plenty of oil on threads to avoid galling)
SOURCE: 1995 ford taurus,broke bolt on tensioner pully while trying to replace belt, now what??
was this the bolt in center of the tensioner pulley? if so you will need to remove and replace the tensioner assembly, if not which bolt did you break?
SOURCE: Rear windshield wiper broken 2007 Chevy Tahoe.
Once you get the nut off of the shaft use a pair of plyers or channel locks and wiggle the base back and forth it iwll come off and then you can replace the wiper assembly without taking anything else off.
SOURCE: 2003 expedition Broken coil bolt Brass Insert
i a broke bolt off also. dont fret it . just make sure coil is on plug good, it'll ride just the way it is.
Testimonial: "thanks for your help!"
