Our garage door opens about 12 inches and stops. It will close but will not open more than 12 inches. We have put WD40 on the hinges and it made no difference.Our garage door opens about 12 inches and stops. It will close but will not open more than 12 inches. We have put WD40 on the hinges and it made no difference.
You can't post conmments that contain an email address.
Check the opening limit dial on the garage door opener unit. You can locate the dial that controls the opening limit on the opener unit and use a flat head screwdriver to turn the dial counter clockwise until the door stops about an inch and a half away from the stop bolt. Then, test the door and make sure it does not slam into the bolt. A video tutorial on how to adjust the opening limit of a Craftsman garage door opener is available on YouTube.
If the above step does not work, check the limit switches on the garage door opener. Most garage door openers have limit switches that control how far the door opens and closes. Improperly adjusting these switches can cause the door to stop halfway. Consult your garage door opener's manual to learn how to adjust the limit switches. Make small adjustments until the door closes fully. Craftsman garage door opening too far and hitting stop bolt easy adjustment (youtube.com)
have a problem which returns every year when outdoor temperatures drop close to freezing. garage door will open only a few inches, then stops. I can close it and try opening it again... same result. After five or six such attempts it typically will open. Interestingly, when I push the switch button mounted on the interior wall of my garage and keep it pushed, the door will open, until I release the button at which point it stops opening.
Check the door springs and also remove the cover from the motor unit and check the drive gear. The door spring could be broken or the drive gear may be stripped.
Loosen the chain enough that you can remove it from the pulley on top of the motor unit. Now with the door closed run the motor until the pulley turns in the clockwise direction and stops. Put the chain back on the pulley and tighten. You may have to tweak the up and down limits now.
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
You may have put the chain back on out of "sync" with in internal up and down stops. You may have to take the chain off the motor sprocket and run the motor to make sure it is stopped in the down position ( watch the rotation of the sprocket to determine up or down position) When the motor is stopped in the down position put the chain back on with the chain Carriage in the down position. Then you can fine tune the up and down stop positions with the adjustment screws on the side.
I would try jumping a wire across the white & red terminal to see if your safety sensors are working Properly! If your door opens you have a loose connection or faulty sensors.
