It will say Authenticating problem unless you have the passkey to the other WiFi networks. So unless its your WiFi or an open network you won't be able to connect.But you can try rebooting your device.
You connect your Nextbook to YOUR WiFI HOME NETWORK (not the Internet) FROM THE NEXTBOOK, not from the laptop. On your Nextbook, go to Settings then Wi-Fi. If your Nextbook is already connected to your WiFi home network you will see the network's name there and you are done. If it is not connected, a list of available WiFi networks appears. Tap on the name of your home network and it will connect to it. If your network is password-protected, you will be asked to enter it.
It could be because of the amount of devices that are connected to your wifi. Too many devices could put a lot of weight on your bandwith causing the wifi itsself to become slower. Disconnect any devices using wifi in your home that dont need to be on every day and try reseting your modem or router. You could also use a usb cord to get a more direct connection or you might have to upgrade to a faster wifi company. If the problem still continues take your device back and get it fixed, call the number in the troubleshooting guide, or visit the nextbook website and make sure you have your device registered.
Hi there
You have checked that you are joined to the network via the router?
The laptop most certainly is.
Try disconnecting the router and turning the Nextbook off for a few seconds, connect the router on again and open Nextbook.
Join the network again and put the password in.
This way of connecting has worked for me. Hope it will for you.
