As said in the title, it doesn't produce any heat. No other indication what's wrong though.
The possible fault could be due to the failure of the heating coil, failure of the control panel or the output drive to the heating coil or it can be one of a loose connection joint of the wiring to the heating coil. You need to recheck the selected program and then check the wiring to the coil. It is important to understand the working of a continuity tester to check the line and the coil which should address the fault. If there is no output from the board then it might be fault of the drive output or the loss of output from the processor which might need tracing of the voltage to the heating coil output. .
SOURCE: Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
