Is unit in a surge protector? Any recent power surges? if you plug it in to a "good outlet" and nothing lights up at all (after a reset), either the ac adapter for the router is dead or the system board in the router is dead.
what is indicated below the blinking lite...if your not getting a signal...try unplugging the units power...wait 4-5 minutes and plug it back in and see if it resets itself....phillip
To reset the D-Link back to the default settings, Press and hold the RESET button and then power up the D-Link. Hold the RESET button for 5 secs until the LEDs flash. Now you can enter the default login & password.
1. check connection by 1st pinging the network card That is go to the dos window and type " ping 127.0.0.1 you should get 4 replies. if not then you need to check the driver set for you network card. 2. check the ether net cord with a know good one 3. reset the router by unplugging it and reboot the pc 4.Call your ISP to check for outages 5. check the power adapter it may be faulty.
Try to reset the router first by pressing the reset button at the back of the router for 20 seconds then power cycle it by unplugging the power for 30 seconds then plug it back in. Here's how to set it up
1. You don't need to use the setup CD that came with it. 2. Make sure you have the proper physical connection 3. From your modem, connect the ethernet to the Internet/WAN port of the Dlink, then your computer to port # 1. 4. Do a power cycle. Unplug power to router and modem. Wait for 30 seconds. Power on the modem first, wait for all the lights to steady then power on the router. You should be all set
