iLO V27DMBX Television Logo
Anonymous Posted on Jun 04, 2013
Panasonix tx L32S20BA
Will not turn on no evident power
Level 3:
Top Expert:
  • iLO Master 76,851 Answers
  • Posted on Jun 04, 2013
iLO Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15003852
Points
237762
Check and replace its main power regulator board. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
2answers
I live near Corpus Christi TX Where's my nearest dealer or repair shop
It is evidently
Creative Sewing Center
11777 WEST AVENUE
SAN ANTONIO , TX 78216
210-344-0791
1helpful
How do i factory reset my panasonix lumix dmc-fz45
Remove the batteries for 60 seconds, at the same time press power and hold for the juration of the time, this will remove residual voltage and reset the processor ic, "long shot" if no change the zoom part of the lens is malfunctioning, the zoom motor or gears are jammed.
Hdmi has board has evidently stopped working altogether. Unit is about 2 1/2 years old
http://www.youtube.com/watch?v=gj0x5S9ez5U
This is the tutorial on how to fix the hdmi handshake issue you are probably experiencing
I can connect my laptop to a monitor and it works ok. When I connect to the Panasonic TX-L32S20BA tv in the same way (through the PC input) and select PC input I don't get a picture. Any suggestions?
Hi
Before connecting it to your Tv try to turn down your resolution settings on your laptop to 680 or something, Maybe your TV does not support the resolution your laptop is in at the moment.
4helpful
2answers
Drivers for Panasonix NV GS5
ลงคอมแล้วเล่นวีดีโอแล้วไม่มีเสียง ของโปรแกรมที่สามารถใช้งานกับกล้องรุ่นNV-GS55
3helpful
2answers
How do I connect an unpowered subwoofer to the Onkyo TX -SR606 .... I am a total numpty when it comes to this sort of thing and am rather surprised that it isn't a straightforward 'screw the cable to the...
I contacted the dealers where I bought the amp and they suggested that I connect speaker cable to both the left and right front speakers and use that to connect the subwoofer.
However, whilst this has worked (sort of) it is evident that to achieve the best results, I will need to replace my existing sub with a powered one in the near future.
Only a temporary fix I'm afraid, but it got the job done.
3answers
Yo do not need software drivers to operate this camcorder.
Full instructions can be found at
http://panasonic.co.uk/customer-Support/download-centre.asp
Let me know if this helps.
Amp Protection Mode
from LANCE P: I fixed it. Be sure that all your speaker connections are perfect. No element frays that can arc, no +/- problems, no single barely connected wire. My problem was volume sensitve and I evidently had one + wire that was loose in the back. I corrected it and ran it all day with surround and good volume with no problems. So diligently check ALL YOUR SPEAKER CONNECTIONS, both in the back of the unit and at your speakers
Top iLO Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
