Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Water leaking into freezer
I have a Kenmore Model #795.75542401 Elite Trio Refrigerator with bottom freezer.  During the last couple of weeks I've had a problem with a layer of ice building up at the bottom of the freezer.  I've cleaned the ice out about 5 times, but the it keeps coming back.  The ice is clean and clear, and I suspect that it's coming from the ice maker.
Have you heard of a similar problem happening, and if so, what area of the ice maker should I be looking at to fix it?
  • lisavoss May 05, 2009
    I have a layer of ice that keeps building up in the bottom of my freezer. I have the Kenmore Trio about 5 years old. I also had the frost build up. I turned of the freezer portion deforsted and then the Ice layer keeps coming back. What do I do?
  • Anonymous May 14, 2009
    I also have this problem. Frost also with build up of ice on bottom. I believe frost comes when you can not close freezer door all the way.
    Ice build up bottom of freezer and after awhile you have problem closing freezer door tightly. Where is water coming from.?
It may be the defrost thermostat. This thermostat turns on a heater in the freezer a couple of times a day and melts the ice in the freezer which should go into a tube that leads to a pan underneath the refrigerator, where it sits and evaporates from the heat of the compressor. It could also be the timer which tells the refrigeator to turn off a couple of times a day and tells the defrost thermostat to turn on.
Posted on May 06, 2009
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Check and see if you have frost build up in the freezer
Posted on Apr 07, 2009
6ya staff
SOURCE:
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
The bottom of the freezer keeps getting a layer of ice. I take the ice out about once a week. Now there is so much ice that it is leaking water on to the floor before it freezes. We have a Kenmore elite...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Jun 13, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
No water or ice or lights on outside of door
I received my Elite TRIO 795.7101 2 weeks ago. I have ran over 3 gallons of water though it. I am still getting a bad odor and taste when I dispenser water from the door.
Nov 03, 2010 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Kenmore/Elite Model 795.7756,7757 Trio: Bottom Freezer Door won't close. The latch or hook at the bottom corner of each side will not hook in.
We have a kenmore elite refrigerator modle number- 795 7756,7757 and it has been making a humming noise very constant now after two weeks, what could it be?
Sep 18, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Kenmore Trio Bottom mount Freezer - water inlet
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} PARTS
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
http://www.appliancepartspros.com/partsearch/
http://appliancejunk.com/forums/
model number
Your model number is needed for more information.
It's usually stamped on a small tag in a visible location on your appliance.
http://www.appliancepartspros.com/modelnumber_locator.aspx
Jan 26, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Elite Trio Model 795.7757960 - Error Code 'IF'
Hi!!! You have a control board problem.Change the control board and you should be okay..Them boards did'nt come out good.Good luck..
Jan 04, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Elite trio
Hello bigmikeegator
Welcome!
You said, you have the Kenmore Elite Trio Bottom Freezer. You moved your refrigerator to a new home and removed the bottom freezer door, but can not seem to figure out exactly how to put it back on correctly.
It's too much for me to tell you myself.
This is easier!
Page 9 shows you how to remove and reinstall doors.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523115.pdf
Thank you,
Huuum,
Please remember to leave a rating!
Oct 06, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Trio Elite 596.75529400
Has anyone got you a solution? I think I have the same problem with mine!
KSheridan
Oct 27, 2007 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
389 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
