I have water damage to my phone. I have it soaking in rice atm but i can't get it past the verizon screen when turning it on. I believe the water got in through my headphone jack on my phone because that was the first thing popping up on my phone. Is my phone permenantly damaged? The water indicator is pink.
SOURCE: water damage on lg enV
remove battery and put it in a bag of rice for a while..any moisture should be absorbed.
SOURCE: my verizon lg vx9800 phone just died for no reason now won't turn
screen just says vx9800 downloader
SOURCE: After water damage my touch screen for my quickfire wont work!
Put it in a ziplock bag of uncooked rice for several weeks. And make sure the battery is out of it. So put in the battery and phone but they should be apart.
SOURCE: LG Dare water damage
If the phone is not completely dry when you turn it on, it will usually ruin it. If you are really lucky, the battery contacts corroded and your phone will work if you clean them.
I have rescued phones from water damage before by disassembling the phone and removing the battery and then drying the phone completely before trying to turn it on.
I'd start looking for a new phone. You can still use your old one for the parts and accessories.
I wish that I could have given you a solution that makes your phone work again.
Thanks,
Tim
