I have a mac computer with os x 10.5.6 software. The midi keyboard I just bought (came with piano wizard software) says it should be plug and play. When I go to the piano wizard software page, it says press the 1st key on my keyboard. Nothing happens. It says above the instruction, no input device. Why won't it recognize the keyboard when it's supposed to be plug and play??
You should go to your utilities --> audio midi setup and make sure your system is recognising your midi device. Play around with your midi settings, see if you can get something going.
Otherwise the problem maybe with the software clashing with Leopard. Double check on the manufactures website that their software is compatible with 10.5.6, or they may have an update for you.
Thirdly you could check if you keyboard is working correctly by opening garage band and making a new software instrument track, press record and see if you get any thing.
Good Luck hope this helps.
Thanks for the help. After talking to the piano wizard tech guy, apparantly I have a faulty keyboard.
