Question about Gestetner C7435n Laser Printer
Gestetner c7435 paper jam at fuser unit
Hello, Hope someone can help asap. I have been running, operating, and fixing when needed a Gestetner C7435 for about 2-3 years. Fairly good at figuring things out. Problem: Error remove misfeed at fuser unit.. I have had this error before and fixed the problem. This time however, I have taken out all parts, examined, used a flashlight, removed and checked the fuser unit at least 4 times, rolled the blue dial etc.. The error message is still showing up. My concern is I'm wondering if the memory on the computer is "messed up". In otherwords, there is no paper jam actually. The last thing I printed were whole sheets, no little bit of paper missing etc... Is there a way to reset the Gest. ?? I print off the newsletter for the non-profit organization I'm pres. of Central Florida Palm and Cycad Society. Needs to be printed so I'm losing time this weekend because techs at where we purchased the machine are not in. Thanks for any suggestions. Diana
  • Anonymous Mar 29, 2014
    left paper jam says to open and remove jam. no paper is jam does this dozens of times when coping need help
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
It sounds as if the actuator is out of position or bad. In the fuser exit there should be a thin little black (usually) actuator that hangs down and the paper pushes/ lifts it off of the switch/ sensor as the paper passes. If this is pulled out of its holder or broken it will act like there is still paper jammed. The actuator looks like a little ' j ' and is pressed into its holder. If this is seated properly then the switch is probably bad and needs replaced. About resetting --- a paper jam is considered an 'A' code and does not need the machine to be ' service reset '.
Please let us know what you find out.
Posted on Jan 14, 2009
6ya staff
SOURCE:
I want to set up ip address for gestetner 2212
Hello.
Follow this steps:
- Press User tools/counter
- Press system settings
- Press the tab Interface settings
After that you will see the options to change the ip address; gatway; sub-net mask...
Hope this helps you.
See you!
Jul 15, 2011 | Gestetner 2212 Digital Imaging System...
Where I can download drivers from the machine DSM635sp GESTETNER Thank You Jorge
Hello!
Gestetner is made by Ricoh. They only change the name. The cross reference for your model is Aficio 2045e.
You can download from the www.ricoh-support.com the driver of Aficio 2045e and your done.
See you!
Jun 23, 2011 | Gestetner DSm635sp Digital Imaging System
My Gestetner 4532 is not printing a code SC 541.Can someone help me?
That is a bad reading temperature of the Fuser Unit.
I will give same steps to unlock it.
Press yellow key
On the key pad press 1-0-7
Old the red key at least 3 sec
Press copy sp
Exit all the way out
Turn the machine Off / On.
This should be good. If doesn't work you have to call a technician to change some parts of the Fuser Unit like Hot Roller and thermistors.
Hope you understand.
Mar 02, 2011 | Gestetner DSM 651 Copier
Do You have anyone in the ocala florida area that services gestetner cpoy machines?
Look for a copier dealer or service center that is listed as repairing Ricoh, Savin or Gestetner. They are all the same machines. In other words your Gestetner copier is made by Ricoh and Ricoh Dealers are far more common and easy to find than Gestetner. If you need to know the exact model then just reply with your Gestetner Model number and I can tell you what the Ricoh equivalent number is.
Hope this helps.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 08, 2010 | Gestetner Copier
Drivers for 3220 gestetner printer fax
http://www.gestetnerusa.com/supportdrivers.html
Aug 29, 2010 | Gestetner Copier
I have Gestetner DSM622 SP, Iam getting Errer code SC546, can someone explain me thanks
sc546 is a fuser temperature detect error. One or both of the thermistors most likely need to be cleaned or replaced, but you will have to go into service mode to reset the code once you do that. You should contact your local service technician or Gestetner dealer, as they can easily fix that problem.
May 13, 2010 | Gestetner DSm622sp Digital Imaging System
Scanner not working (it WAS) on my Brother MFC 210C all in one.
you need to go to control panel and then good to add/uninstall look for the brother software and uninstall it when this is done go back to desk top and reinstall with the disc it came with if no disk you will have to search the brother web site to find the driver for your model hope this helps
May 21, 2009 | Brother MFC 210C All-In-One InkJet Printer
Gestetner
Gestetner is made by Ricoh so go to Ricoh USA downloads for operator manuals.
May 12, 2008 | Gestetner Copier
3 1/2 year old Whirlpool Duet Dryer stopped heating up
it could be several things but the element could should be the last part i would check first if you are still using fuses change them both if that doesnt work call for service call a good service man stay away from major companies they are expensive i know i worked for most of them
Nov 22, 2007 | Whirlpool GEW9250 Electric Dryer
Gestetner C7435n Laser Printer Logo
244 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Bernard D'Souza
gggg
Adorjani Laszlo
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
