Question about Sansui 32" TV
32 inch tv is showing green lines - Sansui 32" TV
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 34 Answers
Picture problem or internal connection or may be mother board loose connection
Posted on Jun 05, 2013
6ya staff
SOURCE:
My 32 inch lcd tv green line in panel
Try unplugging as suggested. Also, try different inputs (HDMI, component, etc.) and different cables to be sure it's not some external item causing problems or just one input. Also plug it into an outlet on a different circuit in your house.
If everything you try still shows the lines, it's probably the screen itself and is too expensive to fix.
Nov 14, 2013 | Samsung LN32A330 32 in. LCD TV
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Element flat screen 32 inch screen jumping and has green lines
I think if it was me I would return for exchange, refund or repair.
Dec 09, 2012 | Televison & Video
My toshiba 32 inch lcd tv has green ,red,and purple squigly lines on the screen Model # is 32AV500U
Change Your Regulator on your Color Mixer check the choke beside it the little yellow trasfomator beside.... It maybe damage too....
Sep 21, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
LG HD 37 INCH TV GREEN LINE APPEARING ALONG THE BOTTOM
On a LX2R to remove the green bar at the bottom or the blue bars on ths side using the sky HD box go to menu and the pip menu at the bottom of the list, access input and make sure the HDMI input is on DTV and NOT PC.
Feb 19, 2010 | LG 32LG30 32 in. LCD HDTV
Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Jun 26, 2009 | Samsung LN32A550 32 in. LCD TV
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
JVC 32 INCH MODEL AV-32S585
is the bright line on the midle of the tv , if it's what u ia vertical problem also sometimes is the flyback , tv needs service ,
Apr 30, 2008 | Televison & Video
Colored Lines Destorted Picture
I had the same problem , sent it into the shop and they said it was a capacitor . It is a $3.00 part and $75.00 for labor . But it did fix the problem . The labor charge was inflated I'm sure so if you someone who can do it and just get the part ,would be the way to go.
Apr 13, 2008 | Philips 32PT5441/37 32" TV
Sansui 32" TV Logo
26 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
