Toshiba Satellite L500 Series Notebook Logo
Anonymous Posted on Jun 06, 2013
My Toshiba L500 Laptop stops working drag and drop and menu in any window or software. No right click menu works. (They open and vanish). after I refresh the computer for long time it works but after
F5 refresh do nothing. even dialog box won't appear when this happens.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 06, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
100
Points
26
Try restoring your laptop to factory settings it is built in to most laptop.
5 Related Answers
Anonymous
  • 306 Answers
  • Posted on Jan 18, 2008
SOURCE: Toshiba Laptop Keys Not Working Right
complete system clean and optimization...possibly formate drive and reinstall windows...being that its an old pc, it probably is slow do to needing a good cleaning. if both those resolutions dont work then its the pc.
Anonymous
  • 70 Answers
  • Posted on Jan 21, 2009
SOURCE: Toshiba Satellite A200 -AH9 Wont Turn On.
maybe you have power conection problem
your problem maybe on the circuit after the battery
so you must check your circuit
or you can contact your Laptop manufucturers
MalKontent68
Stan
  • 748 Answers
  • Posted on Jul 08, 2010
SOURCE: Loud fast beeps on boot.( Toshiba Qosimo F45 )
Looks indeed as if the TAB key was stuck or malfunctioning. The most common cause for such behavior is a liquid spilled on the keyboard, a bit of which got between the layers of the keyboard membrane films and causes intermittent semi-short between conductive areas.
A trace of liquid caught between plastic films is hard to get rid of, as it practically sealed and doesn't evaporate.
If it doesn't go away, you may need to replace the keyboard, which is not very expensive fortunately,
Anonymous
  • 243 Answers
  • Posted on May 12, 2011
SOURCE: my toshiba satellite laptop keyboard just quit and
turn off your laptop by hold your power..ten turn on again and try to press f8 when it booting..go to safe mode and restore it by go to all program, accessories, system tools, and system restore
Anonymous
  • 6771 Answers
  • Posted on Apr 15, 2012
SOURCE: how to fix key on Toshiba Satellite L655-S5061 Laptop Keyboard
The keyboard is made that limited to no service can be done, replacement of the entire keyboard is required. Short term solution is use external keyboard if available.
How do I delete from my favorites
The following document contains information on how to manage your bookmarks and favorites in all of the major Internet browsers. To proceed, select your browser from the list below and follow the instructions.
- Internet Explorer
- Google Chrome
- Mozilla Firefox
- Opera
Internet Explorer
To access favorites:
Press Alt + C
or
Open Microsoft Internet Explorer.
Click on the Favorites IE favorites icon in the upper right-hand corner of the browser window.
Click any Favorite folder to expand and show its contents.
To delete favorites or folders:
- Right-click the favorite or folder you want to delete.
- Select Delete from the drop-down menu that appears.
To move and organize items in your favorites:
- Drag-and-drop your favorites or folders to rearrange them.
Renaming items in your favorites:
- Right-click the favorite or folder you want to rename.
- Select Rename from the drop-down menu that appears.
- Type in the desired name and press Enter.
Google Chrome
To access your bookmarks:
Press Ctrl + Shift + O
or
Open the Google Chrome Internet browser.
Click Customize and control google chrome Chrome settings in the upper right-hand corner of the browser window.
Move you mouse cursor over Bookmarks and then click Bookmark manager.
Deleting:
- Highlight the bookmark or folder you want to delete by clicking it once.
- Press the delete key on your keyboard to remove the bookmark or folder.
- Tip: You can also right-click a bookmark or folder, then select Delete from the menu.
Organizing:
- Drag-and-drop your bookmarks or folders to re-organize them.
Renaming:
- Right-click the bookmark or folder you want to rename.
- Select Edit... from the drop-down menu that appears.
Mozilla Firefox
Press Ctrl + Shift + B
or
Open the Mozilla Firefox Internet browser.
Click Show your bookmarks Firefox bookmarks in the upper right-hand corner of the browser window.
Select Show All Bookmarks.
Deleting:
Organizing:
Renaming:
- Highlight the bookmark or folder you want to rename by clicking it once.
- Locate the field labeled Name: in the lower right-hand section of the Library window.
Opera
or
Open the Opera Internet browser.
Click Customize and control Opera opera button in the upper left-hand corner of the browser window.
Select Bookmarks from the drop-down menu that appears.
Deleting:
- Locate the folder or bookmark you would like to delete and move your mouse cursor over it.
- A circled X should appear in the upper right-hand corner; click it to delete.
Organizing:
Renaming:
Apr 08, 2017 • GPS
I currently have a toshiba l500 and the screen has shrunk only on the right hand side about an inch and has streched vertically past the viewing area. Does anyone know how to fix this problem. Thanks
Open Device Manager, Display adapter, Uninstall Graphics adapter, and drivers if asked. Reboot the Toshiba, allow the software to install the generic driver, Run windows and toshiba updates, Update graphics adapter. post results.
1helpful
Laptop keyboard mouse not working
Toshiba has released a few different advisories related to its Satellite line of laptop computers having keyboard problems. Remember that damage caused by liquid or physical damage is not usually covered by warranty.
Bios Fixes
On Satellite models 1955-S801, 1955-S802, 1955-S803 and 1955-S804, the BIOS (system utility setup program) had trouble reading the firmware for the wireless keyboard. BIOS version 1.40 repaired this problem. The BIOS flash program can be downloaded from the Toshiba website. http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=286356xml&sliceId=&dialogID=124900040&stateId=0%200%2084585964 b> Satellite 1955 Text Anomaly b> Toshiba reported a strange, software-specific problem between the Satellite 1955-S801 and S803 computers and Microsoft Word and Excel. Users who held down the shift key for more than five seconds while using the arrow keys would see their highlighted text disappear. The only provided solution was to use an external keyboard attached with a PS/2 connection or to release the shift key if pausing while highlighting in those programs. General Troubleshooting for Satellite Keyboards b> For general concerns about the keyboard -- if it doesn't appear to be working -- try these few steps. Use the keyboard before Windows loads: hit F1 on the first screen that appears after turning the system on. If they keyboard works here, it's probably a Windows problem. Try attaching an external keyboard; if it works, the internal keyboard is likely broken.
Toshiba Laptop Mouse Problems
Some symptoms that occur with Toshiba laptop mice include jumping and vanishing pointers. These situations have occurred after software upgrades have been made. The problems can often be solved by following basic mouse troubleshooting methods. Overall, Toshiba laptop mice contain the basic functions characteristic of the USB variety.
Function b> The mouse device is used to move, open, delete and otherwise connect with items available on and through the computer monitor. In Toshiba laptops and many others, the mouse pad replaces the point and click USB mouse device. This enables the mobile computer laptop to be more compact, portable and ready to use. b> Features b> The mouse pad on a Toshiba laptop is located in the middle, directly below the keyboard. The control buttons, both primary and secondary are situated below it. The primary key, on the left, represents the left-click button on an USB mouse device. The secondary key on the right represents the right-click button on an USB mouse. This button is used to pull up the short menu of an item after selecting it. Update Keyboard Driver b> Many Toshiba mouse issues can be solved by updating the driver. The driver enables the mouse to function properly. Update the keyboard driver first to increase mouse and keyboard device compatibility. To complete this task, click "Administrative Tools," accessible from the Start menu. Next, click "Computer Management," and then select "Device Manager." Click the "Keyboards" expansion node to bring up the list of installed hardware, and then right-click on the keyboard that is in use. If the "Update Driver" option is available, click on it. Otherwise, select "Properties," go the "Driver" tab and press "Update Driver." Device Manager is a useful tool to update, rollback or uninstall incompatible drivers. b> Update the Mouse Driver b> Update the mouse driver by following most of the instructions in the above section, "Update Keyboard Driver." However, after selecting "Device Manager," click the expansion node next to "Mice and other pointing devices." Select the current mouse device in use and right-click on it. If the "Update Driver" option is available, click on it. Otherwise, select "Properties" and go to the Driver tab and press "Update Driver." b> Check BIOS Fixes b> Some older Toshiba laptop models require BIOS (Basic Input/Output System) fixes. Most of the downloads are available from their website. Since, the BIOS chip is the liaison between the hardware and software, any issues should be addressed promptly. Symptoms, such as erratic mouse behavior or the pointer disappearing, are signs of a need for a BIOS fix or driver update. b> Compatibility b> Toshiba and most Microsoft Windows products are compatible. This is vital when it comes to updating necessary drivers needed for continual operating system function. The service packs they approve of are listed on their website. Hope this helps.
b>
HI I don't Have a recovery Disk for My Toshiba Satellite L500 Laptop. Is there anyway i can recover the windows 7 from the hard disk? Can you please help me solve this problem. My laptop windows 7...
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
2helpful
How do i take a picture on my Toshiba laptop
1. Open a program called"Camera Assistant." This is a Toshiba-supported computr program designed specifically for people with cameras built into their laptops.You can find this by clicking on the "Start" menu and then navigatingto the "Programs" sub-menu. 2. Press the"Picture" button in the "Camera Assistant" program windowto take a picture using your built-in camera. This will take one stillphotograph for every time you click the button. The image you are taking willappear on the right side of the main program window. 3. Press the"Video" button in the "Camera Asst" program window tobegin recording video using your built-in camera. This will record video untilyou press the "Stop" button. The video you are recording will appearon the right side of the main program window. 4. If you can't open"Camera Assistant," reinstall your drivers. Though the camera on aToshiba laptop is designed to work right out of the box, if it doesn't you mayneed to reinstall the driver that makes it work. Look for the CD labeled"Drivers and Software" that came packaged into the box with yourToshiba laptop. Pop it in your laptop's CD-ROM or DVD-ROM drive and install the"Digital Camera" driver contained on the disc.
5helpful
4answers
I have a Toshiba Satellite L500 and the wifi won't work. Have read other forums and apparently it's a faulty wifi card problem. How can I get this fixed without shipping it around the world. I'm in the...
  • Hi, I hope that you are still monitoring this "Website" for a "Solution?" I might be able to help you. Follow these instructions, and we will be able to get you connected. I'm familar with the "Computer Model" that you have, so lets get started! First, click on the (Start button) to open the "Start Menu," next "Type" in the (Search box): "Toshiba." In the Program list; find the Toshiba Application Installer, and "select" to open. The Driver Installer "appear." Now you can select, and install the Wireless Drivers; click on the "Next" button, in the ("choose an item...") window, select the By Name: Wireless LAN Driver, and to the (right), click on the "Install" button. To finish click on the "Exit" button. Note: Follow all instructions thereafter exactly. "I hope this help you, let me know, if possible"
It takes my PC a very long time to boot up, what can i do?
If you have installed any softwares recently it might slow down the pc as many softwares will install a startup file in order to start faster. You can shut these programs from starting up when the pc starts.
I put 2 steps to resolve this in order of simplicity.
Remove icons from the Startup folder
Some programs open with a shortcut icon in the startup folder (Startup icons). Use the following steps to show any startup icons that might be hidden and remove startup icons from the startup folder:
NOTE: Removing items from the Startup folder does not uninstall the software program.
1. Right-click the Start button, and click Explore . The Windows Explorer window displays with Start Menu already selected.
2. Click the plus sign ( + ) next to Programs .
3. Click Startup . The shortcut icons are listed in the right pane of the window.
4. To show any hidden icons, click Tools , click Folder Options , and click the View tab.
5. Click Show hidden files and folders (Windows XP/ME) or Show all files (Windows 98), and click OK .
6. Click an unwanted startup item in the right pane of the window and drag it to a blank area on the Windows desktop. Release the mouse button to drop the icon onto the desktop.
7. Continue dragging unwanted icons until all unwanted startup icons are on the desktop. Click Yes to any window that display asking to confirm the removal of a read-only file.
8. Close Windows Explorer and restart the computer for the changes to take effect. Delete the startup icons that were moved to the desktop after you are satisfied with the way the software programs are working.
If you find that a particular software program should not have been removed from the Startup folder, double-click the startup menu item to open the Startup window. Then drag the icon from the desktop back into the Startup window.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
