2002 Chevrolet Monte Carlo Logo
Anonymous Posted on Mar 22, 2009
Low Tire Pressure Alert won't Clear
I put the correct air pressure in all the tires, and the warning / alert on the message display doesn't go away. Do you know how to clear the messgae form the display?
  • Anonymous Mar 22, 2009
    thank you, gonna give it a try
    light was driving me crazy!
  • Anonymous Mar 24, 2009
    This is really cool, I can guess there are other features available with this option too, I'll play around with it. I already cleared it by disconnecting the cables as earlier suggested, but ths is a cool way too. Thanks
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
232
Points
1. Turn the ignition to ACC or ON and turn the radio off.
2. Press and hold the TUNE DISP button on the radio for at least five seconds until SETTINGS is displayed.
3. Press SEE PSCAN up or down arrow to scroll through the main menue.
4. Scroll until the TIRE MON appears on the display.
5. Press the 1 PREV or 2 NEXT button to enter the submenu. RESET will be displayed.
6. Press the TUNE DISP button to reset. A chime will be heard to verify the new setting and DONE will be displayed for one second.
7. Once the monitor has been reset, scroll until the EXIT appears on the display.
8. Press the TUNE DISP button to exit programming. A chime will be heard to verify exit.
Enjoy!!!
Anonymous
Level 2:
  • Expert 79 Answers
  • Posted on Mar 22, 2009
Anonymous
Expert
Level 2:
Answers
79
Questions
0
Helped
39012
Points
275
2 ways disconnect the battery for about 5 minutes or hook up an obd II and erase the codes
4answers
Low tire pressure light on 1999 oldsmoblie Alero
The TPS sensor may be dirty or defective...be sure all tires are above 33 psi...
3helpful
3answers
How do you reset the low tire pressure light?
To reset the tire pressure system, do the following:
(NOTE!....Do not reset the check tire pressure system without first
correcting the cause of the problem and checking
and adjusting the pressure in all four tires. If you reset
the system when the tire pressures are incorrect,
the check tire pressure system will not work properly
and may not alert you when a tire is low or high.)
1. With the engine off, turn the ignition to ON.
2. Press the MODE button until the DIC reads LOW
TIRE PRESSURE HOLD SET TO RESET.
3. Press and hold the SET button until you hear a
chime, and TIRE PRESSURE RESET is displayed.
You will hear three chimes, then the LOW TIRE
PRESSURE message will go off and the DIC will return
to TIRE PRESSURE NORMAL. If the LOW TIRE
PRESSURE message comes back on, the check tire
pressure system has not reset. Repeat the procedure.
The system completes the calibration process during
driving. The system learns the pressure at each tire
throughout the operating speed range of your vehicle.
The system normally takes between 30 and 60 minutes of
driving to learn the tire pressures. The system normally
takes 10 to 20 minutes of driving in each speed range to
learn tire pressures. The speed ranges are 20 to 40 mph
(32 to 64 km/h), 40 to 60 mph (64 to 96 km/h), and above
60 mph (96 km/h). This time may be longer depending on
your individual driving habits. The learning process does
not need to be completed during a single trip. Once
learned, the system will remember the tire pressure until
the system is reset.
How do i turn off the low tire pressure alert on the message center of my 2004 monte carlo ss?
Fill the tires close to the max on sidewall & check the spare
If the light stays on ,go to a tire store,they will replace any bad
tpms sensor in a tire & explain how to reset
Most cars require a special tool,some don't,read owners manual
My ( ! ) light stays on
Hi there:
Is your TPMS Warning Light On? The Tire Pressure Monitor System monitors the inflation pressure of the tires on your vehicle. If the pressure inside any tire drops 25 percent or more below its recommended inflation pressure, the warning light comes on to alert you.
Should you stop driving and check your tires immediately? It would probably be wise to find a safe place to stop or pull over so you can check the tires. You may just have a low tire that has been slowly seeping air over a period of time. Or, you may have a tire that is going flat. The TPMS Warning Light only tells you the pressure is low in one of the tires, not how fast the tire is losing pressure.
Important: Check the pressure in ALL of your tires, not just the one that triggered the TPMS Warning Light. Why? Because you may have other tires that are also low, but not low enough to trigger the warning light.
If you discover that one or more tires are low, add air to bring them back up to the recommended inflation pressure for your vehicle. You can find this information on a decal which may be mounted in a door pillar, the glovebox, or in your owners manual (which you should carry in your glove box).
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
3helpful
What does warning light that looks like horeshoe with an explanation point inside mean?
The Tire Air Pressure Monitoring System. Intended to alert you when your tire pressure is low. Damaged tires, low air pressure, temperature changes and faulty monitor may all cause the system to turn on. The warning light resembles a horseshoe with an exclamation point in the center.
What kind of tire pressure sensors are on a 2000 olds alero and are they located inside the wheel?
{: ) The 2002 Oldsmobile uses the TIM system. Here is an overview of how it works:
The tire inflation monitoring (TIM) system detects the differences in tire rotation speeds that are caused by changes in tire pressure. The TIM may not alert the driver if the pressure in more than one tire is high or low. The TIM also may not operate properly if the spare tire is in use.
The TIM system can alert the driver when a large change in the pressure of one tire exists. The system only detects a low pressure condition while the vehicle is being driven.
The LOW TIRE PRESSURE indicator turns ON in the instrument cluster if the tire pressure in one tire becomes 12 psi (55 kPa) lower or higher than the other 3 tires and the ignition switch is in the ON position. The message does not appear if more than one tire is low or high, or if the system is not calibrated properly. The system does not inform the driver which tire is low. In order to clear this message, equalize the tire pressures in all 4 tires and perform the Tire Inflation Monitor Resetting. In addition, the indicator may come ON if a low voltage condition is present.
In other words, this is not like the TPM (Tire Pressure Monitoring) system that is being used in later model vehicles, wherein the TPM sensors are inside the wheel, integrated to the tire valve. The TPM sensors detect changes in tire pressure and temperature, and sends out radio signals to the RCDLR, to be decoded by the BCM and the instrument cluster.
7helpful
4answers
How do i fix low tire pressure warning light that will not go away on 1997 lincoln continental. Spare is a donut, so dont think it is involved, I fill tires, and drive 10 minutes and sensor triggers light...
When you "fill" the tires they must be within 3 lbs of each other or the tire pressure warning light will come on. If the tires are "filled" correctly and the tire pressure light still comes on, you may have a tire pressure sensor that has gone bad. You would then have to take your car in to the dealer or tire shop to determine which tire sensor is bad.
Good luck.
2helpful
Service tire monitor on what is the problem? how do you reset the system?
TIRE PRESSURE MONITOR SYSTEM
The Tire Pressure Monitor System (TPMS) uses radio and sensor technology to check tire pressure levels. If your vehicle has this feature, sensors are mounted on each tire and wheel assembly, except the spare tire. The TPMS sensors monitor the air pressure in your vehicle's tires and transmit tire pressure readings to a receiver located in the vehicle.
The TPMS is designed to alert the driver, if a low tire pressure condition exists. This system also allows the driver to check tire pressure levels using the Driver Information Center (DIC).
When a low tire pressure condition is detected, the TPMS displays the "CHECK TIRE PRESSURE" warning message on the DIC, and at the same time illuminates the low tire pressure warning symbol.
You may notice, during cooler weather conditions, that the tire pressure monitor light, located on the instrument panel cluster, and the "CHECK TIRE PRESSURE" message will appear when the vehicle is first started and then turn off as you start to drive the vehicle. This could be an early indicator that the tire pressures are getting low and need to be inflated to the proper pressure.
Each tire, including the spare (if provided), should be checked monthly when cold and inflated to the inflation pressure recommended by the vehicle manufacturer on the vehicle placard or tire inflation pressure label. (If your vehicle has tires of a different size than the size indicated on the vehicle placard or tire inflation pressure label, you should determine the proper inflation pressure for those tires.)
As an added safety feature, your vehicle has been equipped with a tire pressure monitoring system (TPMS) that illuminates a low tire pressure telltale when one or more of your tires is significantly under-inflated.
Accordingly, when the low tire pressure telltale illuminates, you should stop and check your tires as soon as possible, and inflate them to the proper pressure. Driving on a significantly under-inflated tire causes the tire to overheat and can lead to tire failure. Under-inflation also reduces fuel efficiency and tire tread life, and may affect the vehicle's handling and stopping ability.
Please note that the TPMS is not a substitute for proper tire maintenance, and it is the driver's responsibility to maintain correct tire pressure, even if under-inflation has not reached the level to trigger illumination of the TPMS low tire pressure telltale.
The "CHECK TIRE PRESSURE" warning message and low tire pressure light (telltale) will appear at each ignition cycle until the tires are inflated to the correct inflation pressure.
The Tire and Loading Information label (tire information placard) shows the size of your vehicle's original tires and the correct inflation pressure for your vehicle's tires when they are cold.
Your vehicle's TPMS can alert you about a low tire pressure condition but it does not replace normal tire maintenance.
NOTICE: Do not use a tire sealant if your vehicle has Tire Pressure Monitors. The liquid sealant can damage the tire pressure monitor sensors.
RESETTING THE TPMS IDENTIFICATION CODES
Each TPMS sensor has a unique identification code. Any time you rotate your vehicle's tires or replace one or more of the TPMS sensors, the identification codes will need to be matched to the new tire/wheel position. Each tire/wheel position is matched to a sensor, by increasing or decreasing the tire's air pressure. The sensors are matched to the tire/wheel positions in the following order: LF TIRE (left front tire on the driver's side of the vehicle), RF TIRE (right front tire on the passengers side of the vehicle), RR TIRE (right rear tire on the passengers side of the vehicle), and LR TIRE (left rear tire on the driver's side of the vehicle).
You will have one minute to match the first tire/wheel position, and five minutes overall to match all four tire/wheel positions. If it takes longer than one minute, to match the first tire and wheel, or more than five minutes to match all four tire and wheel positions the matching process stops and you will need to start over.
The TPMS sensor matching process is outlined below:
  1. Set the parking brake.
  2. Turn the ignition switch to "RUN" with the engine off.
  3. Turn the headlamp switch from "OFF" to the parking lamps setting four times within three seconds. A double horn chirp will sound and the TPMS low tire warning light will begin to flash. The double horn chirp and flashing TPMS warning light indicate that the TPMS matching process has started. The TPMS warning light should continue flashing throughout the matching procedure. The "SERVICE TIRE MONITOR" message will be displayed on the Driver Information Center (DIC).
  4. Start with the driver's side front tire.
  5. Remove the valve cap from the valve cap stem. Activate the TPMS sensor by increasing or decreasing the tire's air pressure for 10 seconds, then stop and listen for a single horn chirp. The single horn chirp should sound within 15 seconds, confirming that the sensor identification code has been matched to this tire and wheel position. If you do not hear the confirming single horn chirp, you will need to start over with Step 1. To let air-pressure out of a tire you can use the pointed end of the valve cap, a pencil-style air pressure gage or a key.
  6. Proceed to the passenger's side front tire, and repeat the procedure in Step 5.
  7. Proceed to the passenger's side rear tire, and repeat the procedure in Step 5.
  8. Proceed to the driver's side rear tire, and repeat the procedure in Step 5.
  9. After hearing the confirming horn chirp for the left rear tire, check to see if the TPMS warning light is still flashing. If it is, turn the ignition switch to LOCK to exit the sensor matching process. If the TPMS warning light is not flashing, the five minute time limit has passed and you will need to start the process over beginning with Step 1.
  10. Set all four tires to the recommended air pressure level as indicated on the Tire and Loading Information label.
  11. Put the valve caps back on the valve stems. The spare tire does not have a TPMS sensor. If you replace one of the road tires with the spare, the "CHECK TIRE PRESSURE" message will be displayed on the DIC screen. This message should go off once you re-install the road tire containing the TPMS sensor. The "SERVICE TIRE MONITOR" message is displayed when the TPMS is malfunctioning. One or more missing or inoperable TPMS sensors will cause the service tire monitor message to be displayed.
6helpful
2answers
I have a service tire system soon alert on my 2004
you have a bad TPMS (Tire Pressure Monitor Sensor) that is not reading or is having failure problems. Maybe due to excessive pressure loss or the sensor is bad. They require maintenance just as anything else. Sears I know has TPMS kits that replace maintenance parts such as the rubber grommet seal, Lock ring, Special replacement valve core which is made of a different metal than whats is used on NON-TPMS systems, and lastly the TPMS cap. IF the tires were replace then they have to either sell you the maintenance kit or use the same TPMS parts. They would only have to remove the valve core to get the air out of the tire and use that same one again if they are unable to get the kit. GOOD LUCK!
1helpful
Tire pressure reset will not reset
Labatche822,
The process for resetting your Tire Pressure Monitor (TPM) is below.
Good luck, let me know.
Regards.
To reset (calibrate) the system:
1. Turn the ignition switch to RUN.
2. Press the GAGE INFO button on the DIC until
TIRE PRESSURE appears on the display.
3. Press and hold the DIC RESET button for about five
seconds. After five seconds, the display will show
TIRE PRESSURE RESET. If TIRE PRESSURE
RESET does not appear on the display after about
five seconds, see your dealer for service. After you
release the DIC RESET button, TIRE PRESSURE
NORMAL will appear on the display.
driving. During the first 10 to 25 miles (15 to 40 km) of
driving, the system will not alert you if a tire is high or
low. After 25 to 100 miles (40 to 160 km), the
system will only alert you about pressure differences of
12 psi (85 kPa) or more. After about 100 miles (160 km)
of driving, the system will alert you if one tire is
10 psi (69 kPa) different from the other three tires.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
