Beko wma641w reset
Washing machine beko wma641w,does anyone know how to reset this machine?
  • emtysoe Apr 15, 2009
    I tried that but it doesn't work the child lock light is also on any ideas?? thanks :)
    my beko washing machine wma641w fried it's water pump and the
    spin/end and child lock green lights stayed on I've replaced the pump
    however the lights are still on and need to know how to reset. I've
    tried pressing and holding various buttons quick wash and extra rinse
    are supposed to un lock the child lock but it's not working .
    any help would be great thanks in advance
  • 44 Answers
Hi
to reset these al you do is press and hold the start button for about 5 seconds then it should reset if not then you have a faulty pcb
regards
Posted on Mar 22, 2009
My beko washer is doing the first wash then nothing is happening. no spin or drain.
Posted on Oct 14, 2009
  • jsquires1990
    jsquires1990 Aug 01, 2012
    Mine is doing the exact same thing, any ideas on a fix please? john-bart?
6ya staff
SOURCE:
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Oct 30, 2015 | Beko Washing Machines
Beko wma641w wont spin?
Hi if your beko wma641w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jan 24, 2013 | Washing Machines
Beko WM85135LW washing machine
go to there web site or cal the 1 800 #
Jan 22, 2013 | Beko Washing Machines
How to reset or unlocked the beko washing machine timer
My washing machine time delay switch is flashing and I can't turn the machine on what do I need to do?
Feb 07, 2012 | Beko Washing Machines
BEKO WMA641W washing machine not draining but pump working.
Are you sure the pump is working, or it the motor thats running? If the pump is truly working, there is a clog in pump or line. If the motor is working, but the pump is not, you will need to replace. You can usually buy a replacement pump for the washing machine for around $50. They are usually easy to install for a beginner DYI. Make sure you know the easiest way to remove washing machine housing to get at pump and motor. Unplug entire unit. Remove 2 hoses for pump and either screws or brackets to remove housing. BTW if the washing machine won't drain, you are going to have a bunch of water that gravity wants to dump out of machine. Bring pump to parts dealer for exact match.
Aug 21, 2009 | Washing Machines
Child lock and spin/end lights on and stuck need to reset
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 12, 2009 | Washing Machines
Beko wma1510s washing machine dial problem
my beko wma 1510s will not spin and is heating up
Apr 11, 2009 | Washing Machines
Washing Machines Logo
5,785 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
