My printer is Ricoh Aficio 2018d, i would like to have a solution for my problem. My erro code sc144
SOURCE: problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
SOURCE: i am having trouble scanning
If the scanner has not been configured, or network settings have changed, the setup for scanning on this unit is unfortunately quite difficult for a novice. the manuals are readily available at Ricoh.com, under Downloads, but this will not help very much with the scanner config.
Sorry:(
SOURCE: function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
Good luck and please rate me, thanks.
SOURCE: ricoh aficio 2018d error sc302 can someone please
The manual says that this is a chage roller leak.
Means the the high voltage is arching to ground or drum somewhere....usually pinhole in chage roller
SOURCE: Erro code 900.00 service RIP soft ware. What is
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Dell
5310n: error message is 900.00 service RIP software
A few of my users were having trouble with a Dell 5310n
printer. The error message on the display was error message is 900.00
service RIP software. When printing large data files, such as a PowerPoint
presentation, the printer would error out.
Per Dell's recommendation I configured the virtual printer to not spool the
print jobs and send them directly to the printer. This seems to have corrected
the issue so far.
Since I have HP printers on the same print server and none of them have had any
kind of issue printing the same large files, I starting to think that the
problem is due to either bad printer hardware or print drivers from Dell.
http://itadmindev.blogspot.com/2008/07/dell-5310n-error-message-is-90000.html
