Hi. my moto a1000 has the problem of not charging and i know theres a connection as when i do go to charge it and turn it on it flickers for a second and just dies. I have been to some phone shops and the battery doesnt seem to be the problem. i would appreciate if anyone could help
Hey addysam test your charger this way, turn the light off and then insert the charger, there should be a flicker but very dim, if this occurs you will probably need a new pcb or you may have a corroded port.
You have to use right Charger Model :PSM5049 A
Input 100/240V ~50/60 Hz .0.4A (Amper) !!!!!!!
Output 4.4V --1.5 A
The one you using probably is for Blure Tooth wich is weaker:
Model PSM 5037B
Input 100/240V ~50/60Hz 0.1A Amper
Output 5.9V 375mA
if any one else has this problem i'm takin it to a motorola dealer in the next few weeks so ill post the solution wen i get the chance
k turns out ur fone needs a new pcb so itl cost you around 180$ n you will have to send your fone back to motorola to get 1
hi
i have amotorola a1000 phone,but from some time it doesnt charge,i replaced the batery also,but everytime i insert the charger,it shows that no charger detected.i tried many chargers but it shows the same response,
i just said that about the pcb, lol u blind?
