I have set the default in control panel to print 4x6 labels. My mailing labels are generated in a web based program. I use Firefox as a browser. Every time I try to print a label it sets the label size to 4.88x11.00 and ignors the default of 4x6. This only happens in Firefox.
SOURCE: Trying to Print USPS Labels from PayPal on TLP 2844
see if you can set the printer preferences to borderless printing.
SOURCE: Zebra LP 2844 doesn't feed label all the way out
Hi Brian,
When the last label printed is still under the printhead, that means the printer is in "rewind mode". There should be an option for "tear off" mode in the printer driver. This is the mode that pushes the last label printed out to the tear bar. The printer will then "backfeed" when printing the next label. Peel off mode is used if you want to print a label and have it "peeled" off the liner so that you can just pick up the label off the liner and apply it. That takes the rewind option to be installed.
Watch out though, if you are using a label software package, there might be a setting in the label format setup for "tear off" which usually overrides the settings in the printer.
Hope that helps !
SOURCE: Won't print last inch on label
http://www.zebra.com/id/zebra/na/en/index/service_support/options/technical_support.html?country=US&product=58
contact tech support for Zebra LP 2844 Thermal Printer.
SOURCE: On the Zebra it was
I think this is more related to the calibration of the label each time you change the new label size. I use ZM400 and your printer should also have the same setting. Under setting, put the When Head Close setting to Calibration. This will let the calibration perform automatically when ever you load a new label size and close the print head. Well 2 label will be lost every time.
