Samsung Digimax 301 Digital Camera Logo
Posted on Mar 22, 2009
SD memory card will not format in a Samsung Digimax 301.
How can I troubleshoot this issue? I have tried different cards and none of them will format. The screen said card error on all of them!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
667
Points
I own a samsungDigimax 301, 3.2 mpi camera. When I inserted an SD card in the slot, the screen read " card error". Could you guide me as to dealing with this problem so that I may use the camera to take pictures this weekend? Thanks. Mathew.
1 Related Answer
Anonymous
  • 11967 Answers
  • Posted on Feb 16, 2010
SOURCE: keep getting card error message while trying to
Is the slide switch in the unlocked position?
How to unlock sd memory card ,the camera tells me card locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
I need a memory card for my samsung digimax301 camera
The Digimax 301 uses SD cards. They should be available at just about any electronics or office-supply store. Make sure you get an SD card 2GB and smaller, and not an SDHC card 4GB and larger.
3helpful
2answers
My Samsung Digimax A7 camera will not load memory cards. I insert a card and then turn on the device, which prompts a format for the card then I hit yes, the camera thinks for awhile then just turns off. ...
The Digimax A7 may not be compatible with "High Capacity" SD Cards (SDHC). If this is the case you will need to locate an SD card that is 2GB or less in size as anything larger than this is a high capacity card.
SD card wikipedia page
2helpful
I bought a 4GB Memory Card for my Samsung Digimax D53. I put it the camera and Try to format it but it says check sd card. I tried another 1GB memory card and it worked. I know that the problem is with my...
Unfortunately, you can't. The D53 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. Since this is a hardware issue, it is not something that can be changed with a firmware update. You need to use cards 2GB and smaller.
New memory card issue
To rule out a faulty card, format it in the PC using a card reader.
Card Error Message
the error message is because the 2gb sd card is not supported (is too big for the camera)
try 1gb sd card and it should be fine
Card locked
Most SD Memory cards have a little switch on the side to lock them, try switching that to the other position.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
