My vision fitness 9250 treadmill stopped suddenly after I heard & felt a pop in the front under the cover. The elevation works along with all the display. The only thing not working is the motor to turn the belt. The circuit board is lit up. I actually thought the reset popped but that doesn't appear to be the problem. Any ideas out there?
SOURCE: Just bought a 9250 vision fitness treadmill and
First Your outlet to see if power is their, then check on/off switch usually their is an internal light in the switch to show power is to the switch then check the breaker button next power switch. these are a few things to look at. Check if the safety key in place on the upper console
SOURCE: my vision fitness t9450hrt stopped mid run
Use your multi meter check continuity on motor leads if you get about 1 to 1.5 ohms if not leads may have open. You may also need to do calibration if the above check a ok.
SOURCE: I have the Vision Fitness treadmilll #T9450. When
Take the front cover off and see if the drive belt is on the motor. Try running it to see if the motor turns. This could be a motor or controller board problem.
SOURCE: I have a vision fitness T9450 treadmill. My wife
first thing to do is to enter the calibration mode. First remove and replace the safety key. Press and hold the elevation up and the speed down buttons until the machines beeps at you 3 times consecutively. You should also see either the model "9450" or the software code which varies from machine to machine. You should now see one of two things - "eng1" may be displayed in which case just use the elevation keys to get to "eng4" and hold enter for 3 seconds - then press start - this will calibrate your machine and confirm if there is any speed reading issues.
If your machine displays more numbers as it would on the deluxe and premier consoles of this brand then you should see the model of your treadmill at the top left. hold enter from here until "eng1" appears and the perform the steps as above. If the speed is not calculating properly during the calibration the magnet or the speed sensor may have been moved or the magnet could have gone bad - usually slowing to one speed and not changing is the sign of a bad speed sensor. If the control board had any irregular voltage it would shut down as a safety precaution.
