Hi: I need get the part number of the battery for EKG GE model MAC 1200ST Best regards
Here is its part number 303 44270, 18V 1.4Ah nickel cadmium Battery ,
If you wish to have more details check these linkshttp://electro-medical.blogspot.com/https://www.facebook.com/electromedservi...
SOURCE: EKG machine-"Battery is 0/50, Aborting"
all you need is the Battery. These will not run with a bad battery even if it is plugged into the wall.
SOURCE: mac 1200 battery
I am not sure what you are referring to . Do you need just the connecter that is attached to the battery pack? I can provide almost anything for the mac1200. Please let me know.
[email protected].
www.overstockme.com.
Jeff Watson
SOURCE: i have mac 1200st and after self test its write (asic eror)
Why did you change the memory battery, to enable unit to remember time & date?
SOURCE: We have a GE MAC1200 EKG that will only print
The battery is weak. Disconnect the AC, battery,& then replace the memory battery. Reconnect the power battery & AC. Next is a pain in the rear, reprogram the unit; date, ID, setup, ect.
SOURCE: need to replace the 3v
Regards,
Tony
