F35 code what is this. I need help.
SOURCE: Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
SOURCE: Suds and F35 keep shuting down my laundry day:(
I followed the suggestions of opening the lower panel and checking the filter. I found it completely clean but the machine still gave me the SUD code .... so, I detached the hose and blew it out. There was nothing more than still water in it but after running water through it and reinstalling it, the machine work fine once again.
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will
flush and pump out for 5 min and restart on its own..This is caused by
too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
SOURCE: model: wfw9500tw01 f35 error
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: I get F35 error code on my duet washer
Both of these fault codes point to a pressure switch issue. If you remove the top panel, three screws in the back, you will have access to the pressure switch. With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after diong this, you will likely need to replace the pressure switch.
Hello & Welcome to FixYa
F35 error means that there is some sort of issue
with the steamer electronic board and analog pressure sensor has gone bad.
Check that the hose is firmly attached with the washer and is not blocked. You
can also check the water level pressure switch operation. Please get back to me
if you have any other questions.
Kevin
