Question about Tablets & eReaders
Wifi for my Tablet
I have an android tablet and all of a sudden it stops letting me connect to wifi . I'm 100% sure my house has wifi .
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 74 Answers
Thank you for the Video, this made it much easier for me to determine the problem. You are correct, you have WiFi, this is not the problem, the problem is with the Tablet's WiFi Service which is freezing, thus not causing you to access WiFi.
Have you installed any new software lately? Something has broken the WiFi software on your Tablet. If you installed a new App recently, remove it to see if that new App broke your WiFi software on your Tablet. If you have not installed anything new on the Tablet maybe the manufacture downloaded an update that broke the WiFi on the Tablet. If you recently received an Software update from the manufature, let perform a Factory Resetr on the tablet to fix the issue.
Posted on Jun 12, 2013
    New Friend:
For All you WiFi problem, Wifi WPS WPA for PC has all your one stop package for internet connectivity with WiFI. have a look:
WiFi WPS WPA Tester For PC Windows 10 8 7 And Mac Tech Edict
Posted on Nov 17, 2017
5 Suggested Answers
6ya staff
SOURCE:
pakead
SOURCE: connecting tablet to internet
im sorry but mines broken ok
Posted on Dec 21, 2011
jomabug76
Josh Whitehead
  • 1148 Answers
SOURCE: toshiba thrive wifi connectivity
u search wifi networks ,,should have in the menu wifi connections or add a new network,,do a search for wifi,,a wifi scan,,when new netwrks or signal s appear on there,,,if it says open u can go online,,if passwrd enabled or wep or psk or whatever u cant ,,has to be a open signal,,like mcdonalds,,hotels,,,stuff like that,,drive an d search,,
Posted on Dec 23, 2011
BonJo
SOURCE: I have the Archos 101
I had the same problem with my third Archos 101 (I've had two replacements to the first one I bought in June 2011). I just got the third one two days ago and it wouldn't connect to my WiFi like the previous two would. I had to add the 101's MAC address to my router's setup and now I'm connecting to the Internet. Alternatively, if your cell phone supports tethering (my HTC Tilt does) you can tether your 101 to access the Internet through your phone. Mine is working well that way....for now.
Posted on Oct 16, 2011
Jehnavi
  • 4 Answers
SOURCE: my arnova 10 G2 will not connect to wifi network do i need a micro simcard
The powerful 1GHz ARM Cortex A8 processor sits inside an extra-slim 12 mm body weighing only 540 grams meaning your ARNOVA 10 G2 is perfect to gather around on the sofa at home or slip into a carry case for when on the go".
Archos Arnova 10 G2
Posted on May 19, 2012
I got new gigaset qv830 tablet can't connect to wifi & this is my first android
Android Tablet Wi-Fi Authentication Problem [Solved ...
www.tomshardware.com/.../45501-43-wifi-authe...
Tom's Hardware Guide
Oct 23, 2014 - 20 posts - ‎17 authors
I have a new Android Tablet, it seems to work okay, but I keep getting ... I am DETERMINED to get this tablet connected, though, and when I find ...
Gigaset 8" Quad Core 8GB WiFi Android Tablet w/Google ...
www.qvc.com/Gigaset-8-Quad-Core-8GB-WiFi-Android-Tablet-w...
QVC
Free
This holiday season, wrap up the gift that tops their list with this Gigaset QV830 tablet. Work and play--all from the same device.
Newsmy tablet T3 problem wifi connection - YouTube
? 3:48
https://www.youtube.com/watch?v=PSR9QU2eph8
Jul 31, 2012 - Uploaded by Jan Ochotnicky
Newsmy tablet T3 problem wifi connection. ... grey wifi/cant connect to google play error fix (root ...
[PDF]Gigaset QV830 Tablet - User Manual.pdf - liGo
Dec 26, 2015 | Tablets & eReaders
MY POLOROID TABLET WILL NOT STAY CONNECTED TO INTERNET. SAYS AUTHENTICATION PROBLEMS
Android tablet wifi authentication problem [Solved ...
www.tomshardware.com/.../43704-43-android-ta...
Nov 23, 2012 - 20 posts - ‎9 authors
Hello, every wireless device works except my new tablet from Acer running Android 4.1.1. ... Yes, I try to connect to the network router. ... You can hide the SSID - once your Android has it as a saved network it will ... gefraenk said: ... Hello all, I have the same authentication problem, worse, I m not sure what ...
Authentication Problem to Connect Android Tablet - YouTube
? 3:05
https://www.youtube.com/watch?v=2wul81jM7Ts
Apr 2, 2013 - Uploaded by Meroy Diniz
If you have Authentication Problem connecting you androidtablet. ... i got a different problem i cant even turn the wifi on, on my hudl 2 it blocked ...
Dec 25, 2015 | Tablets & eReaders
Why wony my nobis nb09 connect to wifi tablet problems
1. Make sure your device's OS is up-to-date.
2. Make sure Wi-Fi is enabled.
3. Make sure you are using the right password to connect to the Wi-Fi.
Jul 22, 2014 | Double Power Nobis NB09BLUE 9" 8 GB Wi-Fi...
Why will my nextbook 8 not connect with my home wifi
  • Can you see your router from the tablet? If not, check to make sure that WIFI is enabled in the Android settings.
  • Does your WIFI have a password? If so, you need to enter the password in the Android WIFI settings entry for your router.
Jun 14, 2014 | Nextbook Premium 8 Se Android
Android tablet problems
Try going to system settings and select 'About Tablet' then checking you are fully charged and in good wifi signal select 'system updates' Update to any new version it finds.
Make sure it is fully charged with the screen brightness down (so it will last for hours, just in case). The last thing you want is a power down during an update...
Jun 05, 2013 | XO Vision Ematic eGlide 7Inch Touch Screen...
How do i get wifi on my tablet
is your tablet an android or an iPad...If it's an iPad go to settings and click on WiFi Connection near the top of the pick list and it will walk you through the set up. It's very intuitive. Not sure about android tablets.
Sep 21, 2012 | Tablets & eReaders
Unable to connect to wifi it just says scanning
make sure your wifi network is turned on, then open your tablet's wifi and search for it. it should be fine, if not, contact Toshiba for tech help.
Android 4.0 Tablet PC
Feb 04, 2012 | Toshiba Thrive Android Tablet
Toshiba thrive wifi connectivity
Dec 23, 2011 | Toshiba Thrive Android Tablet
Tablets & eReaders Logo
1,065 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
