I used Avery business cards for lasterjets and I found that when I tried printing them they got stuck in my HP Lasterjet 1320.
I tried numerous cards---still no luck.
Anyone know what cards work?
Thanks.
Dan
If the cards are getting stuck in your printer, you first need to make sure the cards are rated for laserjet. If they are, then many times the cards don't like going through the curves of the machine. I would set them to feed from the tray on the front, which should be tray 1, and I would select them to eject out the rear of the printer, which you should be able to accomplish through the print drivers depending on what software you are using to print them.
Please let me know if you would like further assistance with this matter. Thank you.
You should just have to load the card stock in tray1 and open the rear door for the straightest path.
