I have a Maytag electric dryer model # LDE7334ACE that squeaks while running through the dry cycles. It began as some squeaking at the beginning of the cycle and then it would stop. Has recently progressed to squeaking off and on throughout the cycle. Can you please provide suggestions as to what part(s) may be causing this? Thank you. How do you replace the glides/slides? I have a Maytag dryer that's squeaking, took off front and it's clear it's the glides. Found where to buy them just need directions for replacing. Anyone know how?
To change the glides you have someone lift the drum--after taking off the front panel--and pull out the glides. We bought the glides locally and just ordered on line the felt pads that go under the glides, as one was missing. So I haven't actually completed the project but should easily be able to once the felt pads arrive.
SOURCE: Maytag dryer squeaks during cycle
