Question about Comfort-Aire BHD-501 Dehumidifier
BHD-501 D Manual
I need a manual for my dehumidifier. I lost it.
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: Fault Codes
This is more of a tip since I have not actually fixed anything yet. As a test, remove the upper front cover where the buttons and displays are. (2 screws on the bottom then pull off a the plastic snaps) Inside the case on the far left, there is a piece of crimped copper tubing, open on the top end, welded to the refrigerant line, with a black sleeve covering 2 wires out the bottom end. This is a thermistor. I CAREFULLY applied heat with a butane lighter (the mini torch kind, not the "candle flame" kind), taking care not to burn anything. I applied ONLY enough to make it slightly warm to the touch. Do not think of melting anything, as this is not the purpose. Applying too much heat could damage the thermistor. With the bucket in place, the unit started right up. After I did this, it failed again in a few minutes, so I heated it again, and thus verifying it as the source. I have done it a third time, never getting it much over room temperature, and it is still running after almost an hour after doing nothing else. Since this temperature sensing is an analog function to the microcontroller that runs everything, the fault could be any bad connection or solder joint along the way from this thermister to the controller. But is sure appears something in thermistor. I hope my description is complete and clear. Good luck.
Posted on Sep 16, 2008
Anonymous
SOURCE: motor
Your problem may be the thermistor that causes the CH01 trouble code.
Posted on Sep 20, 2008
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: Comfort Air Dehumidifier BHD-501-1
Yes, you have a sealed system leak. Call the number in the book. I beleive that unit is manufactured by LG. You will need to have the unit diagnosed at an authorized LG repair provider. If the unit is under warranty, it will then be replaced by LG no charge, including the diagnostic. Make sure to bring in copies of the proof of purchase. The replacement unit will be shipped directly to you, and you will need to return your old unit, but shipping will be covered by LG with a pre-paid shipping label.
Posted on Jul 04, 2010
Testimonial: "Thanks so much for responding so quickly..I will follow your advise."
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: my dehumidifier model bhd-501 won't shut off&
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Jan 27, 2011
Rich Landrum
  • 4736 Answers
SOURCE: The BHD-501-D dehumidifier developed a
The dripping sound, if it's water dripping into the water collection bucket is normal. The filter is behind the louvers on the front. It can be accessed(depending on the model) by turning the unit OFF, unplugging it and removing the water bucket. Inside the water bucket holder at the top of it's opening, just behind the louvers, you will see a plastic tab(s) pull handle. If the filter has never been removed to be cleaned (shame on you), there may be a piece of plastic tape holding it in place. This was for shipping purposes. Remove it and discard it. Pull the tab handle(s) straight down and the filter and frame should come out. It may be snug, since you have never removed it, so be gently persistent . Since it has never been cleaned in 2 years, vacuuming it will not work. Wash it in warm water and mild dish washing liquid, rinse thoroughly and allow to completely dry, before reinstalling. NEVER operate the unit without the filter in place. As it cause damage to the unit.
If the filter was not where I said to first look. There may be a flip open type rectangular door on the right side of the unit, just behind the front louvers. Ope that door and you will see the plastic filter frame. Pull that straight out and follow the instructions above to clean it.
I hope this helped you and thanks for choosing FixYa.
Posted on Aug 03, 2011
How do you clean filter. I lost the manual
Look on the internet for the make and model they might show you how to do that.
Dec 23, 2012 | Comfort-Aire BHD-501 Dehumidifier
How to disassemble to clean?
The following is a link to the Owners/Service Manual for your model dehumidifier. To see how to dismantle it, see page 10 Dis-assembly Instructions. You can download and print this manual for future reference.
http://www.appliancefactoryparts.com/content/pdfs/116979-8.pdf
Hope this helped you. Please let me know. Thanks.
Jul 04, 2011 | Comfort-Aire BHD-501 Dehumidifier
My dehumidifier model BHD-501-D is icing up. The fan and compressor are running, do I need a new thermostat?
You may, but more than likely, the air intake filer needs to be cleaned and the compressor coils wiped down and cleaned. After cleaning the coils, a light coat of WD40 helps to preserve them.
Before attempting any cleaning or service work, turn the unit OFF and unplug it from the wall outlet and allow it to thoroughly thaw. Keep in mind, a dehumidifier will freeze up, if the room temperature is below 40 degrees. Also, where you have it installed may be a problem. Particuarly, a basement. Where the air temperature is colder at floor level.
In case you have misplaced your Owners Manual, I have included a link to it that you can download & print for future reference. Be advised, your Model Number is not for a Sunbeam Dehumidifier, it's for a Comfort Aire dehumidifier that's manufactured by Heat Controller Inc.
http://www.sylvane.com/images/prodphoto/co758/comfort-aire-product-manual-501-651-D.pdf
I hope this helps you solve the problem. Please let me know. Thanks.
May 07, 2011 | Sunbeam 30Pint Dehumidifier
Jul 04, 2010 | Comfort-Aire BHD-501 Dehumidifier
My dehumidifier model bhd-501 won't shut off& is very hot. What might be the problem? Thanks
heatman101
Jun 18, 2010 | Comfort-Aire BHD-501 Dehumidifier
Not accumulating water and condensation on top
Your unit is low on freon from a sealed system leak. The sealed system should have a 5 year warranty. You need an authorized LG tech to write it up for an exchange. Check your manual and call an LG service dealer.
Nov 15, 2009 | Comfort-Aire BHD-501 Dehumidifier
The unit has started sweating cold water droplets on its top and in the last couple of days it has actually frozen.
Several possible problems. Filter clean? As strange as this may sound you may have lost a little refrigerant. If problem persists after filter is cleaned, then a Tech needs to look at it.
Jul 09, 2009 | Comfort-Aire BHD-501 Dehumidifier
Motor
Aug 21, 2008 | Comfort-Aire BHD-501 Dehumidifier
Comfort-Aire BHD-501 Dehumidifier Logo
89 people viewed this question
Top Comfort-Aire Dehumidifiers Experts
Bill Long
Michael Youngman
Michael Youngman
Tom Chichester
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
