Right before camera locked up several photos had a large black streak across them, each photo with a different shaped streak. Can see the streaks through the viewfinder as taking pic and on end result photo. Camera card issue? But can it cause camera to malfunction? Did usual camera checks including lens, battery taken out, fresh in, but can't get camera to operate.
SOURCE: black screen when in picture mode cant take pictures
PER007 in solution #3 is correct.
I had the same problem with my CoolPix5400 and this resolved the issue.
SOURCE: r05 problem using d70, camera will not take a photo in autofocus
It is actually an error message generated by your compact flash and means that the card is no longer readable. A lot of D70 owners have reported this error without being able to find another solution other than reinserting the card or changing the card to a different brand. You could also try cleaning out the memory card slot and check to see that all pins are aligned and not bent.
Good Luck,
Jeff
SOURCE: Nikon D70s - all photos turn out black
A lot can be happening. Try them one at a time. If the first does nothing, go to the next.
Let me know if we need to go further.
SOURCE: lcd display not working on nikon d40
The D40 works the same way SLRs have worked for the past half century. Only recently have dSLRs acquired a "Live-View" capability, where you see the image on the LCD monitor instead of through the viewfinder.
I realize this probably wasn't the answer you wanted to see, but that's the way it is.
SOURCE: D90 - unable to shoot photo & remove lens from camera body
you must try to remove the lens that lens have some electric contacts and if you set the lens in wrong position that contacts give to the camera some error message
