Smelly water dispensed from ge profile refrigerator
Water dispensed from ge profile artica psc23sgpss is smells like mildew. water filter has been replaced. ice does not smell. water intake is not smelly. help please
Thanks you. I just ran two gallons from the dispenser and the water is drinkable. Have you had this problem? Will this fix last?Thanks you. I just ran two gallons from the dispenser and the water is drinkable. Have you had this problem? Will this fix last?
AnonymousApr 02, 2009
I had the same ordor and taste problem with the {very expensive} water filter system in a GE side by side.I replaced the interior filter plug and bought an inline filter and my problem was solved.I had the same ordor and taste problem with the {very expensive} water filter system in a GE side by side.I replaced the interior filter plug and bought an inline filter and my problem was solved.
You can't post conmments that contain an email address.
Go into the test mode and use 0 4 as the test code between the dispensor board and the main board .(communication test) Sounds like the main control board though .
That is your problem.
The plastic supply lines over time deteriorate and wind up causing the water to smell.
Replace the plastic line with a stainless steel ice maker water supply line available at any home improvement center. They are 1/4 inch inside diameter lines and fittings.
They come in 5/10 and 20 foot lenghts.
After you do this run about 2 gallons of water through the water in the door dispenser. Discard the first 3 drops of ice from the ice maker.
Your ice quality will improve.
One of two things. Water solonoid in back defective or water line insideof freezer door is froozen. I just posted a write up about this. Check other response. UJ63
is the child lock on that would make the dispensers not work, also is the door closed and not bllocked by anything, if thiese are not the case I would reccommend resetting the unit.
Check to be sure the filter wasn't frozen. Temp should not be below 35. A plugged filter will not cause leaking. If water still leaks from above filter, you need to replace filter head.
