Lost installation manual. specificaly wiring diagram
Relocating surveylance camera at buisness. Unfortunatly laborers cut wiring leads before they could be identified. Cannot locate original installation instructions. Need to know wiring diagram.
if the wires are sodered on to yhe ends of the fuse you can carefully cut them right at the fuse but i would hold my sodering tip on the weld and pull the wire off when the solder melts. Unfortunatly you would have to solder a new fuse back in being realy,really carefull about how long u leave the heat on as it could cook the fuse Sounds like a job for a repairman as you dont want to be frying anything else or altering a good amp and if they screw it up they have to take care of it. please let me know how it goes,im curious.
Manufacturer + Model + "repair manual" or "parts manual"
Sometimes the manual will show the various parts on the machine and where they are located. FWIW, some machines do have a wire on the tension mechanism.
Which diagrams do you need?...if it is to install an aftermarket deck, get an adapter so u dont cut into the factory wiring harness..the adapter plugs into the factory plug and allows u to solder the aftermarket radio wires to the other side of it.I have attached a link to where u can get the adapters...unfortunatly this wont allow me to send u my radio schematics that are in PDF format. Car Stereo Installation Parts for2003 FORD WINDSTAR
Actually you can change it without the diagram. Simply cut the wires on the motor and leave the terminal ends attached to both the contactor terminals, and possibly the cpacitor if present. Then install your new fan motor replacing the leads from the old one with the leads from the new one.
But if the new motor has different colored leads, usually the brown leads are attached to the capacitor (it doesn't matter which terminal the leads go to, as long as there are only two leads and it is just the fan's capacitor). And then attach the other two leads to where the other two old leads are. (Naturally removing or swapping new wires to where old ones were.)
I suggtes check the 2005-Jeep-KJ-Liberty-Service-Manual in page 702 and next for Electrical Wiring Diagrams (and Fuses) and
specificaly 8W-41 HORN/CIGAR LIGHTER/POWER OUTLET (page 906).
There is for sure a hook up problem my friend. There should be a memory wire that always has power to it even when the car or the ignition is off. Then there is a switched type wire that only comes on when the cars ignition is on. Check both of these wires in the car. Check the car wiring diagram to confirm this. To confirm the wiring in this vehicle, I
Good Luck with this install. And if all else fails, don't take a chance and blow out the unit, take it to a pro to be installed. Good Luck found the right wiring diagram for your car. Confirm this wiring diagram with this one you have. Go here:http://www.the12volt.com/installbay/stereodetail/955.html
