1) test the outlet wall with a desklamp, if the lamp turn On THE circuit is o.k otherwise, the problem is fuse blown or c. breaker tripped, reset or replace fuse.
2) test the power cord for open or faulty. with VOM usin continuity
3) test the fuse y/o c.breaker inside of machine and reset or replace.
4) Turn on the machine if the machine keep the same simpton, test the key(magnet) the key is a magnet, test vs your magnet from seal magnet of your refrigerator for atraction or repulsion, if doesnot pass the test replace the magnet from some hardware like home depot.
and PROOF again, can be work. see the block,
Otherwise if the problem keep you must call some tech profesional, maybe you have Main switch open or defective and need replace, or power supply, capacitor, transformer, etc defective. or faulty.
God bless you
I have the exact same problem, I just got finished changing out the motor control board, it seemed to work. But I think it only worked because it had been off for so long.
I have the same issue buttons 3, 9, and program works. I tried it later that night when it was cooler and everything works fine. I have my treadmill in the garage so I believe the heat is causing the problem. try moving it to a cooler location
Everything else works fine on the machine, I was running and had turned the fan on. When I was finished with my run, turned off the fan and the fan would not shut off. Took the safety key out and the fan did not turn off. Ended up unplugging machine. Is there any way to fix this problem?
I have the exact same problem, to the T. Has anyone ever figured out how to fix it?
