Question about Radio Communications
Blinking charger They will not stop blinking on chargers
  • Radio Commun... Master
  • 1,655 Answers
Blinking can be a sign of an old or shorted battery, dirty contacts, poor connection with the charger, or a battery that has been drained too low.
First, clean your battery contacts on the radio, battery and charger with a pencil eraser. Try again to charge the battery. (Be certain the radio is turned off while on the charger.)
If this does not solve the problem, try a known good battery from another radio and see if swapping batteries solves the problem. If so, replace your batteries.
If the charger blinks no matter which radio you place on the charger, you may have a problem with one of the charge contacts in the charging tray itself. Once again, process of elimination will determine which one is the culprit. Then replace the bad charger.
The batteries will have a 2 year life expectancy, and there is a date code on the battery. It is either a 3- or 4-digit number. First number of a 3-digit code is the year, followed by the week of the year. Example 324 would be 2013 the 24th week. Four digit codes are similar except the first two numbers are the year, example 1324 would be 2013 the 24th week.
Best regards.
Posted on Jun 16, 2013
2 Suggested Answers
6ya staff
SOURCE:
eradiostore
eradiostore
  • 1655 Answers
SOURCE: Radio won't charge!
I don't know that I have your solution, but I do have a few troubleshooting tips.
Flashing typically means: your battery is possibly old, bad or is not making good contact. Clean your battery contacts with a pencil eraser to ensure they are making good contact with the charger. Also check your charger contact to see that they are free of debris. They can also be carefully cleaned with an eraser. (Do not use any type of solvents on either contacts.)
Second, check the date code on your battery. It is 3 or 4 digit number on the label. Batteries last approx. 18-24 months before starting to fail. Here is how to read the code: 835 would be 2008 the 35th week. If the battery is more than 2 years old, you should consider replacing it.
It is wise to have your radio turned off while on the charger. You can cause harm to the radio if you inadvertently press the PTT while the radio is on the charger. Plus, your radio will never fully charge if left on.
Posted on Aug 31, 2008
I cant find the charging instructions for battery charger. what does blinking green light mean
It may mean that the charger is faulty or its just charging and then when it charges it will stop blinking and just stay green
Dec 21, 2015 | Cameras
NIKON MH26 BATTERY CHARGER BLINKING GREEN LIGHTS
A blinking green light means the charger is charging the battery. A steady green light (same LED) means that charging is complete. If the light never stops blinking and we assume that your charger is working correctly, you may have a defective battery. Rechargeable batteries do not last forever. After a few years, there ability to take and hold a charge declines. It may be time to buy a new battery.
Apr 10, 2013 | Nikon D Cameras
Will a battery charger with too low a rating hurt my scooter? I just found out that the batteries in my scooter are slightly larger than the rating printed on the charger. It seemed to work fine...
hi, if the blinking light never stops blinking that can imply a fault with the charger but first make sure the connections to the batteries are clean and tight.
Dec 19, 2012 | Ctm Health & Beauty
Fuji battery charger BC-45 - red light blinks when I put in battery and battery does not charge
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Aug 03, 2010 | Duracell AA/AAA NiMH Battery Charger with...
Battery charging
Usually when the light on the charger either changes from red to green, or some chargers have a blinking light, when it stops blinking. I have seen chargers which also had a light which would turn off when the battery is charged.
Apr 12, 2010 | Fuji FinePix J10 Digital Camera
I HAVE A 36 VOLT DEWALT RECIP SAW, THE BATTERIES ARE NEW AND SO IS THE CHARGER. BUT THE CHARGER KEEPS BLINKING AS THOUGH THE BATTERIES ARE RUINED. CAN I RESET THE BATTERIES TO TEST
Charger blinks while charging, stops when batteries are fully charged.
New batteries may not be charged from factory. Let them charge overnite and see if it stops blinking.
Feb 05, 2010 | Dewalt Drills
'65 Mustang Hazard Lights
bad ground in rear taillight area
Nov 09, 2008 | 1965 Ford Mustang
Radio Communications Logo
307 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
