PC repair will fix PC issues and Driver solution will get the right drivers for your PC. I use these tools and costumers almost never contact me saying they have a problem.
1) Click Start > Run 2) Type msiexec /unreg and press enter and wait until it appears to have finished. 3) Go back to Start > Run 4) Type msiexec /regserver and press enter. 5) Try to install 'management' again.
hi did you get any particular error during the installation that said fatal error 1935 or 1709 or some other message if you get any error message please mention the specific error code and at what % you get the error is it at 18 % 32 % 56% 94% or 96 % if you get the error at 96% followthe step mentioned below or else please tell us the % at which you get the error insert the cd in to the computer and then go to computers and right click on the cd icon and open it now you will see a Util folder open it and then open CCC and in CCC you will se some files like uninstall_L2, Uninstall_L3, Uninstall_L4 if you have a HP computer then open uninstall_L3 and continue to clean the printer entries If you do not have a HP computer then open UNINSTALL_L4 and continue
after cleanup restart the computer and then go to c drive >>Program files >>HP and delete the digital imaging folder now install the printer software once again if you still get a fatal error at 96% then do not click on the ok button of the error screen directly restart the computer and when it restarts go and try to print in will print fine and still if you have any problem then you can call the HP helpline for free support that is 18004746836 24hrs support
go into Control PanelAdd/Remove Programs and scroll down to remove Java from my system. I click remove and it comes up with the window "Add or Remove Programs: Are you sure you want to remove Java(TM) 6 Update 13 from your computer". I click yes and it says "Preparing to remove" then configuring java.. and then come up with the window:"Fatal Error During Installation"
I've tried enabling logging.. it didn't work.. so that's all the info I can give, I have two HD's mounted.. if that helps.. I don't know. I tried using the install again.. it didn't work believe it or not . Anyway please help
