GE Nautilus runs, but is making grinding noise in all cycles. Any ideas?
Hi you have something in the sump there's a screen on the right side of
the spray arm with 2 screws remove them and take screen off use your
fingers to probe the cavity be careful it could be glass.
If it does not correct the problem
!.You may have an electric pump . and it could be pump without water . so i would say a bad pump.
I hope this helps...I believe it will....Good luck and good day....thank you for your rating my effort....The Fang.
I have the same problem.. I think it maybe the timer... can't wait to hear what the expert has to say...
