try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
We have a Frigidaire CPE30S8CC2 with the bottom bake element not working. We tried to replace it with no luck. The old element does not look burnt out at all. The timer, clock and broil all work just fine. The bake button works and you can set the temp. it just doesn't actually heat up at all. There are no knobs on the controls for any cook top. it is all on a circuit board for overn only. help?
You could also check that the fingers are properly fitted in place at the point where thy join oven and the glass window is closed. make sure that all the elements are working well
A weak oven ignitor will cause this problem. even though it eventually lights the temp has dropped considerably so you don't get consistent temp. turn the oven on and listen for the burner to light. should light within about 2 minutes. if not replace oven ignitor(s)
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
