How do I take out the transmission?
you will need a car lift, and a transmition jack, 1st with car off the ground, take off front tires, drop swaybar, remove a frame from stut tower, unbold big nut on spline, 32 or 36 mm pull out c/v shaft, do both sides, bring car down, unplug cables and wires from transmition, unbolt from motor top half, disconect batery, hot side, raise car back up in air, remove starter, remove inspection plate, unbolt tork converter from flt wheel, 20 0r 18 mm socket and 1 /2 inch drive breaker bar to turn over motor to get to bolts, connect jack to transmition, remove rest of bolts lower half, remove crossmember, wiggle transmition with pry bar, lower jack..... it should take you about 4-6 hours if you never done one, if you have air tools, you can nock off 2 hours easy..
