Refrigerators Logo
Posted on Mar 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error Code Er FF
Kenmore bottom freezer model number 795.77304600
Keep getting error code Er FF. I looked this up and apparently its a freezer fan error from ice build up? How can i fix this and what do i need to parts/knowledge wise to do so?
Anonymous
Level 3:
  • Kenmore Master 3,361 Answers
  • Posted on Mar 23, 2009
Anonymous
Kenmore Master
Level 3:
Answers
3361
Questions
Helped
1029278
Points
10654
Replace the defrost heater and defrost thermostat in the freezer.
Hi I have a problem with my LG Refrigerator model GC-L247SLUV it's not working it keeps on displaying code
Unplug the LG fridge and wait 20 minutes - Plug back into power - Many times the code will clear or reset. If not keep reading below... -The majority of the time it is the freezer fan causing the Er FF error code. The FF error code indicates that the freezer fan motor is defective.
https://removeandreplace.com/2017/08/27/lg-refrigerator-error-code-er-ff-how-to-clear/
https://www.lg.com/us/support/help-library/error-codes-refrigerator-CT10000021-1441392048805
1helpful
My Hitachi Freez R-W660FEUC9X flashing error code F1 05. Anyone knows what does this mean?
2answers
5helpful
2answers
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
We are getting the ER FF display on our water dispenser - out freezer seems to be OK - our fridge is not cold
This error code Er FF indicates a problem with the evaporator fan motor but it can also be with the main control board. When the power cord is disconnected for 30 seconds and then reconnected, it resets the board. Sometimes this procedure corrects the problem and sometimes it does, for only a short period of time. Usually in this case, the main board will need to be replaced. Could you locate the model number Click Here for example=> Kenmore Model Appliance Number Locator
At the lower part of the page you will see just who made your Refrigerator. If you find that number to confirm the model number this will be easy for the DIY. Let me know what lower fan and freezer fans are doing. Your Kenmore Model Number should look like this for example only=> 789.154698 If you still have trouble or need assistance let me know and rate my post once I see your model number, Thanks, Sea Breeze
5helpful
Kenmore elite error message er ff
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
5helpful
Kenmore ELITE error code ER FF
ER FF error is malfunctioning evaporater fan
hope this helps
3helpful
2answers
Error Code Er FF
ER FF - found in another post = Error Freezer Fan. Removed freezer back panel (inside freezer), defrosted ice build up around fan. Error message gone for now. Easy fix at midnight - 20 minutes. Will be looking into ice-up cause.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
