Unit poers up without error, but any scan or copy generates 3200 error and Lamp doesn't light up at any stage.
C 3200 ERROR
This error belogs to Exposure lamp problem ? cause of this error 1. Defective scanner PWB. 2.Defective exposure lamp or inverter PWB. 3.Incorrect shading position poor . 4.poor contact of the connector terminals Solutions:- 1. Replace the scanner PWB and check for correct operation. 2. Replace the exposure lamp or inverter PWB. 3.Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor. 4.Check the connection of connector YC7 on the scanner PWB, and the continuity across the connector terminals. Repair or replace if necessary.
