Get a audio lead red and white male fittings 1 end and 3.5mm jack the other plug red an white into aux leads on player press the volume button in when the player is on standby and in the menu turn on the aux then your ipod will then work in your aux mode
If you dont have an MP3 or Ipod input, then the best way is to buy an FM transmitter. This device plugs into your cigarette lighter and when connected to the Ipod will transmit the signal to the stereo unit. this device is actually like a micro radio station that you have to tune in on the Kenwood. These units are available at Wal-Mart, K-Mart, or online at Ebay, and Amazon.
SOURCE: NEED SECURITY CODE
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
