I hadn't used camera in a while & it needed to be charged. I put it on the charger and the nex day it still wasn't charged so I assumed that I needed a new battery which I purchased and then charged but it didn't charge either. Can the charger go bad? How can I check?
SOURCE: charger blinks red and does not charge
This maybe a solution. I had the same issue just now. Pulled battery, put back in, placed on dock, and still blinking red. So I removed the camera from the dock, pulled battery, put same old battery back in, placed on the dock and turned the mode switch on right away before it started blinkin red. It seems to be charging now with one bar and has not gone blinking red for 15 minutes.
I was outside with the camera in 10 degree weather taking pics of my dogs but had been inside for 20 minutes before placing it on the doc. I think something may have happened with the charging circuit and turning it on right away with it on the doc may have reset the charging. Try it. Hope it works for you.
SOURCE: m753 kodak camera does not come on.
go to the nearest electronic place that sells cameras they will tell you wats wrong
SOURCE: my digital camera will not turn on
My problem is now fixed! I put in a fresh set of recently purchased non-rechargeable batteries into the camera.
I was out-of-state visiting my Dad and taking many photos of his things. I ended up replacing my batteries with some he had around the house just prior to the first instance of camera's problem.
[I do not know the age of Dad's batteries!]
I went to Kodak's website [link] www.kodak.com/global/en/service/products/ekn027989.jhtml?pq-path=3906/1931
On this page is a heading "Troubleshoot And Repair," and I followed the link - Step-by-Step Solutions & Repair .
Perhaps this would help others who posted....
Marcia
Solved Issue with Kodak EasyShare CX7430 Digital Camera
SOURCE: the camera won.t turn on the battery
I had the same problem with flashing red light on my charging dock (within 10 sec after 2nd green light came on). I did fix it. There is a rust brown securing tab that holds the battery in place. Mine must have a broken spring..... So, I put the battery into my camera, pushed securing tab over the battery and then wedged a toothpick tip to keep battery tab in place. Once back on the charger, I had no more flashing red light. The battery is charging correctly. The problem was that the battery was not held down into place correctly. I now just have to unwedge the toothpick tip to remove the battery...but not really an issue at all as I keep the battery in there all the time. Very easy fix!!!
Others suggested to reseat the plastic dock. But mine was secure. Somewhere there is not a good battery connection that is causing the red flashing light. I am thankful to figure it out. Hope this helps you.
