VCR will not accept any tapes. They go in part of the way and then eject. This happens with all tapes.
You are more than likely using a pre-recorded tape and a timer programis set to record. If you are trying to record, make sure the protectiontab is in place.
Here is the trouble shootingmanual.
You are more than likely using a pre-recorded tape and a timer program is set to record. If you are trying to record, make sure the protection tab is in place.
Sounds like a mechanic problem, check for fragments of tape inside.
Check the spring that is working or not.......
that spring is inside the try area....
