Grandstream GXP-2000 IP Phone Logo
Posted on Mar 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't hear anything when I make or recieve a call
When I make a call, the phone calls the second party, but I can't hear the phone ringing, or I can't hear the any sound from the other party. The call does go through, and when the person picks up, sometimes they can hear me. I just set up my phone and it worked fine, but the next day this was my problem. I tried resting the phone, but I still got the same thing.
  • 1 more comment
  • gjbarnes Mar 24, 2009
    How do you restore factory setting?
    I reset factory settings after unplug...same thing?
  • gjbarnes Mar 25, 2009
    Yes
Anonymous
Level 3:
  • Master 412 Answers
  • Posted on Mar 24, 2009
Anonymous
Master
Level 3:
Answers
412
Questions
Helped
271776
Points
1322
Unplug the phone for 10 mint....
and also try restoring it to factory settings.....
  • Anonymous Mar 25, 2009
    Ok... THats mean you need to contact to your service provider.....and the problem is due to only service provider....
    Good Luck!!
    please do rating...
    Thanks for using FixYa.
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
5helpful
My panasonic phones do not ring when an incoming call is coming in. There is a dialling tone on all 3 handsets and they all appear to be working ok
Ringer turned on? quite common and I'm a phone repair man. Does the calling party hear multiple rings? If it rings only once and goes to silence on the calling party end, there is a high resistance short on the line and it must be repaired.
The person i ring can hear me but i can't hear them
The problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
When i make a call they can hear me but i cant hear them...and when my phones rings or i when i try to play a song no sound is coming out
Take care.
Not able to talk
have the phone check fully the microphone needs to be replaced and the earpiece as well........the housing by the earpiece might be block so take a small flatbit screwdriver and have try to to clear it.
3answers
I cant hear anything out of my headset
Is the headset paired and connected to your phone? Is bluetooth turned on in your phone? Look for the bluetooth icon on top of your phone's screen. Let me know what model phone you have and I can help you troubleshoot.
Landline phone
I gather you are using an IP phone. I would have to say that the only way to trouble shoot is to use a protocol analyzer. If you connect it within the IP path you will be able to see both ends of the call and determine if the call was received or not and if the other end is responding to your call. Your IP PBX might be the problem I would run a diagnostic on it and if it fails, I would suggest calling the manufacture to see if there are any tests you can run.
Top Grandstream Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Grandstream Computer and Internet Expert? Answer questions, earn points and help others
