Cars & Trucks Logo
Linda L Blakeman Posted on Jun 19, 2013
Car wont start, fuel not getting supplied
For the past 2 weeks or so , I noticed at least once a day, while driving, all of a sudden, my car shuts right down on me and when I'm pressing gas pedal, there is nothing. Then have to restart it. It has been doing this for the last couple of weeks without missing a day. It just recently did it yesterday , and now it wont start at all. There is lots of power, new alt, battery, fuel filter, no fuel leaks, also, already did troubleshoot on fuel injectors, no problems with them. Can someone help please! Thanks
A
Anonymous
What about a worn out fuel pump & fuel pressure
when it shuts off?
  • 1 more comment
  • Linda L Blakeman Jun 19, 2013
    Hi Peter, I always thought once a fuel pump go.s it would just go all together, I just went outside, and it started for me. Is it at all possible, that the CCRM(Fuel pump relay is gone) High current fuse
    Or the electronic fuel sending unit
  • Linda L Blakeman Jun 20, 2013
    Just checked all repair paperwork, and the fuel pump was replaced in June/2011
5 Related Answers
ourhowse
Dar
  • 2007 Answers
  • Posted on Jul 20, 2009
SOURCE: 1998 3800 v6 firebird... wont run right after starting
Possibly a weak fuel pump, idle air control valve, vacuum leaks, or loose or damaged wiring in the ignition system. Check for vacuum leaks first. That's the only one that won't cost anything. Make sure all intake bolts are tight, and all hoses are connected properly and in good condition.
Anonymous
  • 1071 Answers
  • Posted on Aug 20, 2009
SOURCE: car just shut down on highway. Mech says I need a new crank senso
no you just need to remove the timing belts and crank gear all can be done in car i am a kia master certified technician and have replaced a few of these on both v6 and 4 cyl
Anonymous
  • 7 Answers
  • Posted on Jan 24, 2010
SOURCE: 1993 Chevy S10 Blazer engine hesitation with smoke from exhaust
Had a 94 Olds Bravada that did a similar thing and it was EGR valve on the front of the intake. It' s easy to take off and clean with WD 40 and if you have an air compressor blow it out good.
saailer
David Burbee
  • 1871 Answers
  • Posted on Feb 25, 2012
SOURCE: Code P0342 - Chevy Aveo Sedan 2006. Last 2 months, when starts the car engine getting
Hello! The trouble code is telling us that the voltage to the Camshaft Positioning Sensor (CMP) is low...The connector that plugs into the sensor could be open, the sensor itself defective or low battery input to the sensor...See diagrams below as to sensor location...Lets eliminate...The wire colors in the CMP plug are...Pink...Black/White...And Light Blue/Black...If you connect a voltmeter to the Pink wire you must read 5 volts...Push a safety pin into the rear of the in-place connector into the Pink wire so it contacts the pin that the wire is crimped to...(+) probe of meter clipped to that pin and (-) probe to bare metal chassis ground...Key on...Meter set to read 5 volts...If 5 volts is present that eliminates a battery fault...Next push the safety pin into the Light Blue/Black wire...Turn on key...(+) probe to that pin...Should read about 2.4 volts...If you read nothing, or less than 1 volt the sensor is defective OR the connector pins to it are fouled...Pull plug and inspect both male/female pins for oil...corrosion...etc...Radio Shack sells a product called DeOxit...It's the best (no touch) spray contact cleaner...Send results...PS...Best meter to use is a digital one...$20...Guru...saailer
Remove engine cover:
CMP at top of drawing with timing chain cover removed for clarity...
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Anonymous
  • 84 Answers
  • Posted on Sep 03, 2012
SOURCE: 1994 Toyota Camry XLE replaced fuel pump & filter car starts & idles but boggs out and cuts off when pressing gas pedal?
have you pulled codes or checked the fuel pressure? It could be a host of things, like a clogged air filter restricting the flow of air into the engine, a bad air meter, clogged injectors, etc. Engine codes will help you start narrowing things down.
Has the engine air filter ever been changed?
Testimonial: "Thanks for your advice I really need the car so any help is welcome!"
1helpful
Car wont start
Check...
1. Loose or broken spark plug cable.
2. Spark plug gap.
3. Leaking of air from cylinder head gasket.
Suzuki esteem lack of power / hesitation
I noticed you did a lot in trying to find the problem but I noticed that you never ran the fault codes to check for where the problem was. Run the fault codes and tell us what they were.
206 BMW 525i periodically wont start
Sounds like your key switch is malfunctioning.
94 Cadillac deville just stopped running suddenly. could smell fuel the past week,
As with any no start situation, you will need to figure out if you are lacking spark or fuel to proceed.
If you have spark to the plugs, you would check the fuel pressure with a gauge. You can try spraying starting fluid into the throttle body to substitute the fuel supply for testing.
While driving the other day my car suddenly shut off but fortunately I coaxed to the side of the road.
There so many cause for a car to just shut off. First thing you do is chec for spark. If no spark check for blown fuse. If there is spark check for fuel. Do this by spraying some starting fluid in the air intake. If it starts then dies then it is not getting fuel. The cause can be a fuel pump fuse, clogged fuel filter, or worst a bad fuel pump. If there is spark and there is fuel and it still wont start, check the timing. If timing is good and still wont start or it starts and then stops, then the exhaust is blocked. maybe by corrotion or something.
1helpful
2004 alero cranks but wont start.
I had the same problem with the fuel pressure. I had a brand new fuel pump that was 11 months old. I had that fuel pump replaced. It worked for about 2 weeks and the car would not start. I had to get the security system replaced. The car runs now. I have had this car for three years and it has put me through hell.
Car wont start after shut off
Probably your distributor cap or rotor, also check the spark plugs and spark plugs wires. This may happen when , after a certain amount of time, the distributor becomes to hot, or the wires, and then a huge resistance is built. Did you notice that on a long distance your car would shut off than you have to let it cool down before it starts back ? On oldder cars it's a pretty common problem.
2answers
1997 CHEVY BLAZER SHUTS OFF WHEN DRIVING
Sounds like water/debris in the gas tank. Try adding dry gas to the tank. Changing the fuel filter also a good idea.
Down to the point.
First check the battery voltage if its less than recommend voltage then its the battery ,try jump starting the car if its works then you need replace its battery ....
Good luck...
2answers
Engine shutting down in extreme heat
Mine does the same thing as far as shutting down on long trips---usually 1 1/2 - 2 hours. I don't think it's overheating....it's got something to do with antitheft system
Top Mercury Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mercury Expert? Answer questions, earn points and help others
