AUDIO
Revision: May 2004 2002 Altima
AUDIO PFP:28111
System Description EKS002KQ
BASE AND MIDLINE SYSTEM
Refer to Owner's Manual for audio system operating instructions.
Power is supplied at all times
through 15A fuse [No. 31, located in the fuse and fusible link box]
to audio unit terminal 6.
With the ignition switch in the ACC or ON position, power is supplied
through 10A fuse [No. 6, located in the fuse block (J/B)]
to audio unit terminal 10.
Ground is supplied through the case of the audio unit.
Audio signals are supplied
through audio unit terminals 1, 2, 3, 4, 13, 14, 15, and 16
to terminals + and - of front door speaker LH and RH
to terminals + and - of rear door speaker LH and RH
to terminals + and - of tweeter LH and RH.
BOSE® SYSTEM
to audio unit terminal 6, and
to Bose speaker amp. terminal 1.
Ground is also supplied
to speaker amp. terminal 17
through body ground B117.
to speaker amp. terminals 23, 24, 25, 26, 27, 28, 29, and 30.
Audio signals are amplified by the speaker amp.
The amplified audio signals are supplied
through speaker amp. terminals 2, 3, 9, 10, 11, 12, 13, 14, 15, 16, 18, and 19
to terminals + and - of subwoofer LH and RH.
SPEED DEPENDENT VOLUME CONTROL (MIDLINE SYSTEM AND BOSE SYSTEM)
If activated, the radio output volume will be automatically adjusted to compensate for increased driving noises
at higher driving speeds.
The radio receives a vehicle speed signal from the combination meter, and selects the output volume.
Um... What is the question?????????????????????????????????????????????????????????????????????????????????
