Need it to to change channel from video 1 to video 2 I have no remote and need it to work please help
In most cases, with a universal remote control, you can't select the TVs inputs. It will be best to buy an original remote control. Contact the authorized service centrer, or dealer. If you wish to get set-up codes list to some universal remote controls, check this link. http://electrohelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or, view it in 'Timeslide' option. It has set-up code list and proceedings to most popular brand remote controls. If you wish to buy one universal remote control, check to which remote control have set-up codes to your Brand TV. Buy that brand remote control, according to availability. But, input section function is not guaranteed.
SOURCE: My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
SOURCE: need to put tv on video 2 mode to use ps3 and no remote
Have you tried running through the channels until they wrap around and start over again? Alot of TV's will throw the AV inputs in there before the first broadcast channels.
If not (and you're gonna hate my answer, but be kind to the messenger please!), you may have to purchase a new remote control from the manufacturer, which can be exorbitantly priced. Most 'Universal' remotes will act just like your Dish Network remote, and you will probably not be able to use any of your set's advanced functions through them.
I would recommend searching the web for the appropriate replacement remote control, you may get lucky on eBay and save a few bucks. Hope this helps!
SOURCE: I lost the remote for
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: DVD CONNECTION
AV/TV Button
Press ¡° AV/TV¡± button,the will be some word show on the right top
of the screen, press ¡° PROG+/-¡± to select the AV source, and then
press ¡° VOL+/-¡±to enter AV mode. Hope This helps. If the dvd player is HD then it will probably be component 1 or 2.
Good Luck. Please rate me.
http://www.denver-electronics.com/UploadetFiles/154/25/DFT-1504_Black_English.pdf
This is the manual if you want or need it.
SOURCE: remote
dollar store has a cheap 1$ remote with auto search on it,Make sure it has the paper work in it you need a instruction book (paper),does not work on the magnavox TB100MW9 hd box, but it is a 4-in one and works with my vizio,sony,samsung,and yamaha equipment, any auto search remote should help, in the store you can read on some universal remotes list of what they support.
