HI. this code represents a drainage problem. The drain hose may be bent or clogged with debris or, it may be a clogged drain filter as well. I recommend cleaning and straightening the drain hose and i would also clean the drain filter. this should fix the issues you are having with this washer.
please rate and god bless.
What you have is actually a "DE" error. (Drain Error) Check the filter behind the access door on the lower left front of the washer. If the filter is clear, there may be another cause, like a impeller came off the pump motor shaft.
